Old 03-21-2006, 05:00 PM
Plumpton Plumpton is offline
Send a message via MSN to Plumpton
Angry Oil Pressure
Just curious to know how much oil pressure i should be running while idling and then while in stop and go traffic. My gauge is in kpa and it seems rather low to me. Usually between 25 and 75 kpa.
Old 03-28-2006, 04:00 AM
robertjr's Avatar
robertjr robertjr is offline
Re: Oil Pressure
All you need is about 10psi per 1000 rpm's. the conversation is roughly 7(kpa) to 1(psi).
Old 03-29-2006, 12:42 AM
chevrods chevrods is offline
Re: Oil Pressure
so if i only ever get 20psi in my 86 C-20 with a 350 i could be a bit screwed cuz i think i have only ever seen that thing go up once and that was just to 25 psi
Old 03-29-2006, 09:16 AM
formulaross formulaross is offline
Re: Oil Pressure
GM gauges are notoriously inaccurate. That MIGHT be the problem.
Take a known good gauge and tap into the oil system to check the actual pressures. It could be your pressure sender, your gauge, or your engine (worn pump, engine bearings, etc.).
Old 03-30-2006, 12:39 AM
Talking Re: Oil Pressure
Thanks for the advice guys I really appreciate it.
