Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 03-21-2006, 04:00 PM
MichelleLayug MichelleLayug is offline
Exclamation Monte Carlo SS 01 PLEASE HELP!!
Hello, I need some help if anyone can offer it... or suggestions, please! I have a 2001 Monte Carlo SS, with about 85,000 miles on it. All highway miles, if that matters. Recently, I've been haveing problems. The Driver Information Center (where it tells you what outside temp is, avg. miles per gallon, etc...) has been acting up, along with my A/C and cruise control.
Every once in a while, I can start the car up and everything works just fine... especially in the morning. But other times, I start the car up and the Driver Info Center, A/C and Cruise control do not come on at all. Also, when this happens, usually the A/C and CC kick on about 10 minutes after the car is started but the DIC does not com on at all... does anyone have any ideas of what might be wrong? I checked the fuses, they are all fine. I heard it may be a computer problem... do you have any idea of how much this will cost? Is this a serious problem??... anyone with suggestions, please offer them, I don't want to try to start my car one day, and have it not work! I'm worried ... thanks a bunch!
Michelle
Old 03-21-2006, 04:12 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: Monte Carlo SS 01 PLEASE HELP!!
Sounds like the computer. it may just need to be reset, if reseting the computer does not work, then it may need to be replaced which could cost you up and over $300. I am not sure how to reset the cpu, infact I am trying to find that out now with my truck.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 03-21-2006, 04:28 PM
Exclamation Re: Monte Carlo SS 01 PLEASE HELP!!
Thankx for the suggestion, I'll look into how to reset the computer... hopefully that works, I feel so helpless, I don't want my car to die on me...
Michelle
Old 03-21-2006, 04:31 PM
I think you will be fine. I will let you know if I get the procedures to reseting a cpu.
Old 03-21-2006, 10:42 PM
phewop118 phewop118 is offline
It might also be your ignition. It sounds wierd, but w-bodies experience strange electrical symptoms when the ignition goes bad.
Old 03-22-2006, 08:22 AM
Does that mean I may have to replace the ignition? It sounds expensive... I hope not. I started my car up this morning and everything seemes fine, but as soon as I go to lunch today, I know that all those things won't come on again... it's really weird, it's so aggravating!
Thanks for the suggestion!
Michelle
Old 05-01-2006, 01:51 PM
bpay1 bpay1 is offline
I have the same problem with my monte, also about same mileage for whatever that is worth. Have you found a solution to this?
Old 05-08-2006, 01:02 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree that your problem is most likely the ignition switch/harness assembly. It will cause other issues too, like heater blower inoperative, radio display issues, instrument cluster anomalies, etc...
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-29-2006, 10:59 PM
macdhb macdhb is offline
Greetings
I just had the same problem with my 03 SS. I had the computer reset. THat cost 80 dollars. It worked fine for 2 days. Started the same thing again. It ended up being the ignition. That was 289 dollars. All is well with the SS now
