Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-21-2006, 12:07 PM
klippersr klippersr is offline
battery draw
My 1991 mercury grand marquis drains battery during cold or hot temperatures, but sooner when cold related, about a 12hr period and some times takes a week. Has new alt, numerous batteries, and alt disconnected and still battery goes dead. Something is turning on and is a slight draw, but what. Need help.
Old 03-22-2006, 09:49 AM
reekor reekor is offline
Re: battery draw
Check on some of the stupid things that maybe staying on such as, map and dome light, light under the hood and trunk and glovebox, visor light, pushed in cigarette lighter.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 03-22-2006, 10:16 AM
Re: battery draw
GREAT tips, and appreciated, but have checked all these in detail, and still pulling my hair out. Need more advise.
Old 03-25-2006, 01:44 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: battery draw
You do a draw test by using a test light....remove the negative battery cable, put the test light on the battery negative post and the other end on the negative cable end you just removed, the light should light, then start pulling fuses and when the light go's out see what is on that fuse circuit, replace fuse, and then start unplugging those things on the circuit and when the light go's out, you have the problem...hope this helps.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
