Old 03-21-2006, 10:23 AM
Rock_28 Rock_28 is offline
Unhappy air charge temperature sensor
i seem to have coolant leaking from the sensor on my 2000 se 3.1 v6. Is it possible to just change the sensor to stop the leak or can be another problem to it?
Old 03-21-2006, 10:29 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: air charge temperature sensor
What year and model Grand Prix?
If you are referring to the engine coolant temperature sensor you can try tightening it down some more. If that doesn't work then replace it. The threads on these type sensors are self sealing and no teflon tape should be used.
Timeslip 08/12/06
AF Community Guidelines
Old 03-21-2006, 10:39 AM
ty bnaylor3400. its a 2000 se 3.1 v6
Old 03-21-2006, 10:52 AM
BNaylor's Avatar
The torque value for the ECT sensor is 18 ft-lbs. About similar to installing a spark plug. Good luck!
Timeslip 08/12/06
