Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 03-21-2006, 01:01 AM
BlackPhantomSX BlackPhantomSX is offline
underdrive crank pulley
Is a underdrive crank pulley a good buy for may 240sx. My friend said that it gaves power to your car but it get it power because its taking it from the battery, and altnortor. in the process damaging ur car,TRUE OR FASLE. Ifeel my friend is blowing smoke up my ass, help me out.
Old 03-21-2006, 01:12 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: underdrive crank pulley
FALSE. its a good mod. the only downside is that if you have a big sound system you might go thru batteries because it will make your alternator not charge your battery as fast. otherwise its completely safe.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 04-06-2006, 08:43 PM
wotandsdwys wotandsdwys is offline
your friend has no idea how an engine works if he thinks that an underdrive pulley takes power from your battery and alternator and gives it to your engine.
but yeah, like he said, I have a full pulley set on my car and my alternator only charges like 13volts on idle, and the headlights would dim too, but that was fixed by grounding my alternator better.
but what you need to look out for is that your temp might go up because it also turns the water pump less, which might cause your car to overheat. But that just mainly happens on cars that have a small cooling system, but the 240 has a little bit more than it needs stock, so I really dont notice any problems and I'm running a single cam radiator in my car.
Old 04-07-2006, 11:21 PM
David_NISMO David_NISMO is offline
Doesn't the KA technically have a Harmonic Dampner. Which means that the potential for greater engine wear is there, because the crank was designed to have a Dampner on the end of it to not only reduce vibration, but balance the entire rotating assembly.
Solid piece Crank Pulleys are believed to be damaging to motors.
But, honestly, in an inexpensive and easy to rebuild motor like the KA, it's not that big of a deal.
And yes, HP is freed from accessories, to be used by your wheels.
If you want some more easy engine response and HP, get some electric fans off of an Altima at a Junkyard and dump your stock clutch fan. This is little stuff, but cheap and easy.
Rolling in a power by a
Old 04-08-2006, 10:52 AM
nissan_240sx nissan_240sx is offline
Yup there are no dampeners or harmonic balancers for the KA24E or the DE. There is an extra slab of metal on the back of the ka24e and de engines that are suppose to dampen any type of extreme turbulance.
If you get an after market pully kit you should be fine. KA's are low rev engines that don't need any type of sufficient dampening.
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 04-08-2006, 01:08 PM
Cool, that's good to know.
