Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 03-21-2006, 01:48 AM
r16409 r16409 is offline
Exclamation Check engine light on but NO CODES!
Hi,
Read the threads and went to two different Autozones and tried getting the codes on my 2000 Civic with 77K miles, but all I could get from the scanner was a "link error". The guy at the autozone said he had seen the same issue with a CRV.
Anyone have any ideas on this?
The car runs bad at low RPM's with hesitation and bucking.
Thanks!
Old 03-21-2006, 11:41 AM
exman98 exman98 is offline
Re: Check engine light on but NO CODES!
maybe just a fuse
so you are asking me what should you make? Ummmmm.... well i vote meth lab.....helps out the community and gives people like you a job
I love out driving people.
"what's all those cylinders for anyway"
Old 03-22-2006, 09:14 AM
No, not just a fuse.
According to the dealer the ECM, (computer), is bad and the IACV, (Idle Air Control Valve) caused the ECM to "short-out". This makes no scense to me and I was not allowed to speak with the tech to verify how he came to this diagnosis.
The car only has 77k Miles and I am the origianal owner. If this is acceptable for Honda I will not buying one any time soon.
Old 03-29-2006, 03:40 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Did you turn the igniton to the "run" position (the spot that turns on the dash warning lights but doesn't start the car) after attaching the scanner?
I'd call the dealer asap. The computer and some other emission components should be covered by a federally mandated 80k warranty, check your warranty manuals for details. GL
Old 03-29-2006, 04:16 PM
r23760 r23760 is offline
Yes, myself 2 independent honda mechanics and two dealers ran the scanner with the Ignitin in the "On" Position.
One dealer said the the IACV "Shorted" out and caused the computer to go bad. They offered to conver the computer under the 80K emissions warranty but not the IACV. I asked to speak to the Tech about his diagnosis but was refused so I took it to another dealer. The other dealer replaced the computer and ran the car for a while and tested and retested with the scanner and said the IACV was NOT bad and that other dealer was probably just trying to sell me a new IACV.
I am going to complain to Honda about the first dealer.
Thanks
Old 03-31-2006, 02:38 PM
johnb16a2's Avatar
Strange, last year my CEL came on in my car (with code p1457). The dealer replaced a purge solinoid and two way valve for like $250. A few days later the CEL came on again and the dealer said the same thing. When the solinoid shorted out it fried part of the computer. I also had my ECU replaced under the 8year/80k warranty. All has been well since then *knocks on wood* GL
