Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 03-20-2006, 11:32 PM
d4h8a1's Avatar
d4h8a1 d4h8a1 is offline
Send a message via Yahoo to d4h8a1
93 del sol starting prob
I took the engine and tranny out of a 93 del sol type S the other day to fix a third gear syncro problem and install a new clutch. The car does not start anymore. There is gas and air, but no spark. I tested for spark by grounding the plug and cranking the car. There is a new distributor cap and rotor, new plug wires. No fuses are blown. The ignitor tested bad at autozone, so i got a new one of those too. Any advice?
Old 03-21-2006, 05:26 PM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: 93 del sol starting prob
did you put the motor back *in*? lol sorry.. couldn't resist.
Did you double check to make sure your plug wires are in the right order? It can be a pain if you get them backwards, or if your distributor is in, but in the wrong position. Try turning your distributor forward (not a whole lot.. use the little slots that it screws in with, and turn the whole thing forwards). That will advance your timing. When I replaced my dizzy in my old car, I had it in but turned all the way back, the timing was so retarded (yes that's the correct term) that the car wouldn't start. Turned the dizzy back towards the front of the car and she started with no probs.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 03-23-2006, 12:00 AM
d4h8a1's Avatar
I made sure to mark on the dizzy where to mount it so i wouldnt have to mess with the timing. After a new ignitor didnt work i was out of ideas (because the coil checked out) so i got a new dizzy and coil. After a new distributor, cap, rotor, plugs, plug wires, coil, and ignitor - the car started.
I talked to two people at different places that said even though the coil's resistance checks out it could still be broken.
In any case, the car runs now. =)
Old 03-23-2006, 12:07 AM
94SolGrl's Avatar
well that's good to hear... and by the way, it's just a del Sol S.... it's not an S type, Type S, or any of that crap. It is an S model. You drive an 83whp go cart. Don't try to make it out to be something that it's not.
~*Emily*~
HOW TO POST PICS!
Old 03-28-2006, 12:04 AM
d4h8a1's Avatar
An 83 whp go kart? There is nothing i want more. =D The less technology and computers - the more purely mechanical mechanisms there are the more enjoyment i get out of driving it.
