Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 03-20-2006, 09:52 PM
olds8894 olds8894 is offline
Banned
Send a message via Yahoo to olds8894
Cool Cheap Power Increase
Anyone have some ideas on how to increase power on a '94 Olds 88 at a minimil price?
Old 03-21-2006, 10:18 PM
fourtwenty fourtwenty is offline
Re: Cheap Power Increase
Think this would do anything?
http://cgi.ebay.ca/Up-MPG-and-Power-...QQcmdZViewItem
Old 03-22-2006, 09:00 PM
Banned
I've heard of these things. Theres another one that sits in a little sylinder and spins. Pretty much they claim it works like a super/turbo charger by compressing air. I have heard that these things dont work. Its almost worth buying one and trying it though. If anyone on here knows anything about em, let me know.
Old 03-22-2006, 09:13 PM
Banned
I've done some research and come up with a conclusion. They dont work.
What I used to do for a little extra boost when I went to take on the local posers is disconnect the MAF sensor. That adds a hell of a lot more HP. I'm pretty sure thats not good for the car so I stopped. Sure put those little Pontiac Grand Ams to shame though. Gotta love a street racing Olds.
Old 03-24-2006, 06:28 PM
Banned
Still wondering if anyone has soem ideas.
Old 03-25-2006, 11:53 AM
atv087 atv087 is offline
Send a message via AIM to atv087 Send a message via Yahoo to atv087
run a can of seafoam through your engine
Old 03-25-2006, 02:43 PM
Ofnarcr Ofnarcr is offline
It does not work. Dont but it.
If you look further into your intake there is a MAF screen. This screen is a last resort for large particals that could get into the engine. It also makes the air flow linear. Makeing the air spin like that would be cancelled out by the screen..
Old 03-26-2006, 10:37 PM
Drewet88 Drewet88 is offline
maybe you could rip off the cat and run straight pipes.
i heard that add hp.
Old 03-27-2006, 07:20 PM
Banned
Already ripped off the cat
Old 04-17-2006, 08:55 AM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
actually gutting the cat will cause u to lose power. it's the muffler that take the most power out of you the engine. what you should do is run straight glass packs, and build or buy some custom exhaust headers. then get a hi-flo cat. contrary to popular belief. guting the cat causes the air to slow down in the absence of the material. when the gases exit this empty space, they must speed up again. this robs you of a lot of power.
another idea is to run an exhaust dump valve that you can switch on and off(so you don't get caught by the cops)
Old 04-17-2006, 07:18 PM
Banned
This exhaust dump you speak of...is it cheap and easy to install? I didn't gut the cat though, its just a pipe and since the pipe was put in, theres a lot more power, enough to roast the tires pretty good.
Old 04-17-2006, 08:17 PM
it's pretty easy, but you need to be innovative. i would prolly cut a section out and put a butterfly valve in it's place. You would have to do it so that when the valve is open, it make the exhaust go down a dump tube. when the valve is closed, it would force the air to go through a muffler... simple in concept, but you may need to do a little improvising to get the butterfly valve to work how you need it to. if you don't wanna be creative, you can always buy one(i don't know $$$ amount) or do a little research on google.
Old 04-18-2006, 11:40 AM
basically you could use a Y pipe with a cap on the end or something when you press the button or pull on a handle it opens up so that the air comes right out of one side of the Y pipe while the other side that goes to the rest of the exhaust is closed off my friend did something like that on his jeep but didnt gain any power he actually lost power because of the very little ammount of backpressure.
Old 04-19-2006, 03:29 AM
Hansnet's Avatar
Hansnet Hansnet is offline
not so much available for your year, you also have the granny trans 2.84 so it will always be on teh slow side....of course if you have $1500 you could drop a 240HP L67 in there.....bolts right up, you would need to find the whole drivetrain from a yard, PCM, harness, trans, and motor.
Old 04-19-2006, 09:45 AM
another ideacould be to put in a more aggressive cam... actually i don't know how well that would work with the olds 88.... neways... you could always take the belt off, and get one to bypass the ac unit or take the ac out completely, that might give you a little more power... or as a last resort you could put some cool paint on it to make it look fast...
