Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-20-2006, 09:47 PM
redsaturn redsaturn is offline
Question trouble codes, 0341, 0507
i have a 98 sl with 1.9 w/ sohc. i have just purchased a code reader. the code is telling me ...p0341..cam location signal error....and ..p0507..idle rpm too high. what or where is the cam location sensor and how do i change the idle to idle properly. i am used to engines that don't have computers. i have a chilton saturn book, but it is not much help. how can i correct the problem causing these codes? or where do i start?
Old 03-20-2006, 10:01 PM
Cat Fuzz Cat Fuzz is offline
Re: trouble codes, 0341, 0507
Well, I can't help you specifically but I can tell you that the idle is not adjustable. Something is telling the PCM to increase the idle speed. That could be a number of things but its most likely a vacuum leak or a bad Idle Air Control motor. Someone else might have more insight.
Old 03-21-2006, 12:57 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
po341 is kind of a fluke on a saturn. its detecting a high resistance/misfire. there is no cam sensor on a saturn, it has a cam sync generator which is apart of the ignition module below the coils. id say you need to check your intake gasket. spray carb n choke or starting fluid around the the intake to head surface and see if the engine rpms change.
once youve done that, then come back with any information and go from there.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 03-21-2006, 02:29 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
http://www.saturnfans.com/forums/showthread.php?t=43380
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 03-21-2006, 09:06 PM
sounds like great help guys! thanks and i will let you know what happens.
Old 03-27-2006, 08:06 PM
Smile Re: trouble codes, 0341, 0507
well it looks like your help worked. the 0507 seems to have been a crack in the pcv hose, replaced that. and the 0341, i replaced the plug wires and plugs. been over 1 hundred miles and no check engine light on. so thanks guys!!
Old 03-27-2006, 10:38 PM
Cool
