Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-20-2006, 05:27 PM
Silver Blue '97 Silver Blue '97 is offline
Headlight multifunction sw. - easy fix
I read some posts on how to fix this. They suggested to take apart the steering wheel covering to get at the switch to clean it, here's what I did.
1: Disconnect the battery and put he steering wheel in the up-right position.
2: Took the rubber boot, that covers the bottom half of the switch, and pulled it out and up over the lever then and it in place with a rubber band.
3: Then I tied the lever up, the same position as your high-beam, to the steering wheel to keep it out of the way.
4: If you look to the left of the lever in the column you can see 5 round brass contacts with small holes in the center arranged in a half circle. Those are contacts that have to be cleaned.
5: Spray the contact cleaner then spray the dry air to dry the housing out, do this for about 4 or 5 times, rotate the headlight switch for each time you spray.
6: Let the car stand for 15 to 20 minutes to insure that its dry and thats it.
7: Re-connect the battery, reset the date and time and your done.
It worked for me on my ‘97, hope this helps.
Old 03-26-2006, 09:06 PM
rbajjk rbajjk is offline
Thumbs up Re: Headlight multifunction sw. - easy fix
This is exactly what I did. It has been fixed now for two months. Took a total of 10 minutes, then I let a box fan blow onto the steering column for about an hour - just to be sure that any pooled up contact fluid had every chance to evaporate.
Easy fix for what looks like an expensive electrical problem - with lights flickering on and off - and lights staying on - and that ominous clicking sound.
Anyway, couldn't have done it without this board.
Thanks again to all who read and post here!!!!!!
Brian.
Old 08-02-2006, 12:58 AM
deltaflash deltaflash is offline
Smile Re: Headlight multifunction sw. - easy fix
Great info, This also fixed my 99 Aurora crazy light show... Thanks
Old 09-04-2006, 03:32 PM
fufu valve fufu valve is offline
just like to say thanks from another satisfied customer.did it on my wifes car it worked like a charm.saved some $$$ i'll probably need it to fix the traction control that keeps coming on for no apparent reason
