ABS error code help
I am looking into buying a '98 Century, but it has an ABS light on. I took it to a shop and the code is 1246, rear ABS channel wil not move. Big problem? Is this the kiss of death as far as repair cost? Thanks in advance!
Re: ABS error code help
False codes are easy to read with some scanners, it should be driven with an abs function scanner to look at and compare wheel speeds, it is possible it needs a wheel speed sensor.
It looks like a real code Max. It is consistent with a GM ABS Mark VI system for a "W" body car. It is not wheel speed sensor but a rear channel fault. I've seen the problem before and normally it is a bad ABS motor pack.
Bob, not that this is the case, but using a Snappy scanner I have had multiple codes for the abs when the lite was on ,followed the trouble tree for the codes, no fix, somehow the scanner set these codes when it was a speed sensor, so now I always road test first looking at comparative wheel sensor inputs to be sure I am on the right track.
Thanks, guys. This sounds like a dealer only repair? Cost estimate?
The only valid ABS codes for a GM "W" body car are what is contained in the GM service manual. A lot of them do not match up to a Snappy scanner database or other ABS capable scanners. The possible defective parts specificed for this type of failure is the ABS motor pack or ECBM module per GM.
Thanks for the comments. Can someone tell me where the ABS motor pack is located?
Had a similar problem with my "92 Park Ave... Solved it with a 2" piece of electrical tape, placed over the light on the dash. Inspection guys don't see it, so no problem. Good luck
