Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 03-20-2006, 04:39 PM
TheS25 TheS25 is offline
71 Chevelle Malibu, Starts but doesnt shut off...
That Chevelle was sitting for a while before the starter died. I replaced the starter and it starts up fine. But when i turn the key to shut it off nothing happens, it just keeps running when im in the full off position. So i replaced the ignition switch and got the same result. Besides the whole ignition system what else could cause this?
Old 03-26-2006, 06:37 PM
bluechevelle's Avatar
bluechevelle bluechevelle is offline
Send a message via Yahoo to bluechevelle
Re: 71 Chevelle Malibu, Starts but doesnt shut off...
Check all your grounds.
Old 03-27-2006, 11:20 AM
DCarr511 DCarr511 is offline
Point or HEI Ignition or ??
It sounds like the small wire on the outside of the solinoid is touching the main pwr supply from the battery.
If this is a HEI ignition, that wire isnt needed.
Old 06-07-2006, 01:04 PM
justinp01 justinp01 is offline
Check to make sure that your main power on your starter is not touching one of the smaller wires....I did that once, had the same problem.
