Old 03-20-2006, 04:16 PM
92grandprixx 92grandprixx is offline
Rear Brake upgrade on 92?
My 92 keeps going through rear brakes and i am getting sick of it!...I thought i read somewhere where you can upgrade to the newer 94 style rear brakes without alot of hassle? anyone heard of this or have info to help me?
thanks!!
Old 03-20-2006, 05:58 PM
maxwedge maxwedge is offline
A990 racer
Re: Rear Brake upgrade on 92?
94 is the same. Binding and frozen sliders were the biggest issue, make sure the calipers release completely when the brake is released check this with the rear jacked up of course, the was a recall back when to replace the lower slider with a SS type to try and stop corrosion from forming. Also check for frozen parking brake cables also common.
Old 03-21-2006, 06:21 AM
Thanks...I put 2 new calipers back there...Just sometimes i have like half pedal before i have brakes then sometimes i have great brakes..Front brakes are new too pads, not calipers could one of those be sticking and not applying or not really a issue there? also i cut both cables back there as they were binding up and sticking...do they need to be hooked up to adjust the brakes properly or no?
thanks!
Old 03-21-2006, 07:22 PM
A990 racer
Aha, the parking brake cables is how the rear brakes adjust, using the pb periodicasy will keep the caliper pistons adjusted properly. Replace them them.
Old 03-22-2006, 08:00 AM
I have wondered if that made a difference or not....So just replace the ones going to the calipers or the one going to the parking brake too? I think that oine is fine its the others that were corroded...And then how do you set them up how tight do you go on the cables to adjust everything right?
thanks!!
Old 03-22-2006, 08:46 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The parking brake will adjust itself with a few applications of the parking brake pedal after the calipers are installed (assuming all the cables are free). The new (or reman) calipers you bought should have the new bronze guides installed that won't seize. Use your parking brake occasionally (hardly anyone does anymore with an automatic) to adjust the rear calipers and you should not have any more issues.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
