The other day when i started my car I didn't hold down the key long enough for the engine to start so I tried it again. The second time it sounded like it wanted to go but before I could do anything I believe I heard a pop and all the electronics shut off. this i mean by alarms, radio, dash, interior exterior lights, ignition, everything. I do know that the battery is good becuase everything I have hooked up to the toggle switches thats run straight to the battery still works. I looked at all the fuses on the side of my dash and they all look fine, my car is a 89' GTU 2.8 v6 if this matters at all. Please notify me as soon as possible if you might know what it is, becuase for now it looks like I'll be walkin. Thank you very much.
Re: No Power Problem
you might want to check the fuses one by one. mainly the accessories fuse, it supplies power to the ignition, radio, alarm, ect. if this does not help, look at your ignition coil, soilinoid. after you have check these, then its most likely a sensor.
Hope this helps. Terrell |
fusable link in the "+" battery wire that leads to you fuse panel...
