Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-20-2006, 02:17 PM
Ramblin Fever Ramblin Fever is offline
Help - Lower radiator hose will NOT
stop leaking. It's dripping where it connects to the bottom of the radiator; have tightened the clamp before, but, after 2-3 minutes, it's stops leaking on it's own.
It only leaks when truck has sat overnight on a real cold morning, i.e. below 20F.
Thought for sure I had it stopped, as there has been a few mornings of 16-19F and it's been fine.
This morning was 15F and it started leaking again. This hose is new, but everytime I think I've got the clamp tight enough, within a day or so, if it's real cold, it'll start leaking again.
Funny thing is, is I'll tighten the bottom up a bit, then the top of that same hose will start leaking. Tighten the top up, and within a few days the bottom will start leaking - but it only does this below 20F.
I'm about to give it up and just replace the damn hose again.
Could it be the simple case of just not having the clamps tight enough?
Any ideas, this is really starting to pi$$ me off!
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 03-20-2006, 05:54 PM
directory's Avatar
directory directory is offline
Re: Help - Lower radiator hose will NOT
i think it's time for a new hose and clamp
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 03-20-2006, 06:16 PM
Hose IS new that's the thing, doesn't even have 500 miles on it yet. I will definitely get more clamps, wondering if they loosen up over time, as far as I know, this clamp is new as well, but that doesn't mean it was good to begin with.
Well, it was 10F after work today, laid down on the cold ground and tightened that lower clamp another good turn, then started the truck, no leak, for now.
What I'm worried about is overtightening, I was told to be careful seeing as the lower part of the radiator mount is plastic, I'm afraid of overtightening and bending/breaking the radiator mount.
1997 3.2L V6 Rodeo
Old 03-20-2006, 06:31 PM
bishop242 bishop242 is offline
Are you re-using those "double-wire" type clamps that come from the factory?
They are worthless. If all else fails, try the racing type clamps that are about 1-1/4" wide. Most auto parts stores carry them.
2000 Trooper limited
1991 Trooper V6 "The Tank"
2000 Rodeo LS 4x4 SOLD
1989 Trooper 2.6 - R.I.P. Killed by a 6$ heater hose
"Tow strap? Sure... I'd be happy to pull you out"
Denver Colorado
Old 03-20-2006, 07:14 PM
Nope, these are your standard clamps from Autozone, nothing special about them, but they are not the OEM clamps - agreed, those were worthless.
These clamps look like they're fairly sturdy, but looks can be deceiving. I'll check into that tommorrow.
Can't remember off the top of my head, and it's too cold to walk outside, does anyone remember if I can install a new clamp without having to take off the hose? I'd hate to loose all my fresh antifreeze.
1997 3.2L V6 Rodeo
Old 03-20-2006, 07:46 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
You should be able to. All you have to do is loosen the clamp all of the way and the band will come out of the "tightening thing-a-ma-jigger".
2000 VW New Beetle TDI
2007 Honda CR-V
Old 03-20-2006, 08:22 PM
Originally Posted by Canucklehead
"thing-a-ma-jigger".
Haven't heard "thing-a-ma-jigger" in years!
1997 3.2L V6 Rodeo
Old 03-20-2006, 08:45 PM
I figured you'd understand it if I used such an extremely technical term.
2007 Honda CR-V
