Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 03-20-2006, 01:58 PM
eclipser2001 eclipser2001 is offline
suspension
"When using Eibach Prokit springs recommended setting on a 1~4 is no
lower than 2, 1~8 no lower than 4."
Why should I go no lower than these settings? Is there a way around this?
Will it damage the shocks or springs or car? If it will damage the spring, what type of spring should I get to go all the way down?
Is "firmer" better?
And does the 4 and 8 pos. have different names?
I did search (in here and in club 3g) but these questions are original, and were not found!
My ride:
2002 ZX-6R
CH-53E
Want to get:
2008 6R or 10R
Evo VIII or
STi
Old 03-20-2006, 05:59 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: suspension
let me give this a try...
1-4 and 1-8 are settings on shocks
stock shocks are at1... i think...
4 and 8 being the stiffest within their realm
now, if you took a spring designed for 2 and harder on a 1 level shock, then you will bottom out on a hard bump. bottoming out is very hard on the parts in your car, and your suspension because it is an immediate stop of any upward and downward motion.
firmer can be better but you will feel the road more, and it may not be good for the road you are on, say if it is a very bumpy road, you would be more likely to lose control on a 4 or 8 setting than if you were at a 1 setting, but you wouldn't want a 1 setting b/c then you would bottom out.
does that make any sense? springs and shocks is a science to find the right balance b/t stiffness and handling that will give you excellent ride quality and performance.
that's all i got someone else come help... my head will explode soon
Don't act like you don't love it.
503/2000
Old 03-20-2006, 08:30 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: suspension
what shocks do you have?
Old 03-21-2006, 05:18 AM
808drifter 808drifter is offline
Re: suspension
i have AGx's and put them at hightest setting.
Old 03-21-2006, 09:00 AM
Re: suspension
i was really asking Eclipser2001. but good info to know though. i have mine on '1'.
Old 03-21-2006, 03:27 PM
Re: suspension
i wanted to get the KYB AGX/ Eibach pro-series spings really soon. i wanted to get the firmest ride i can get with AGX struts even if that means getting different springs. well maybe not THE firmest, but a really really firm ride. i was looking at the JIC FLT-A2 but there $2000, i wanted close to this in suspension firmness.
My ride:
2002 ZX-6R
CH-53E
Want to get:
2008 6R or 10R
Evo VIII or
STi
Old 03-21-2006, 07:00 PM
Re: suspension
try tein drop springs i think tey also have a highr spring rate.
Old 03-22-2006, 07:09 PM
Re: suspension
will they work with the agx struts?
and will i be able to get the 223% (setting 4 and 8) stiffer ride?
""Setting#:
Relative Value
1 - Same as Factory (100%)
2 - Same as our GR2 products (10~15% firmer than Factory --115%)
3 - 50% firmer than #2 (172%)
4 - 30% firmer than #3 (223%)
For an eight position adjustable product, the damping force values are
approx. the following: With #2 being Factory at a relative value of 100,
#1 = 95 (5% softer than Factory)
#2 = 100 (Factory damping force)
#3 = 107.5 (7.5% firmer than Factory)
#4 = 115 (15% firmer than Factory)(GR-2)
#5 = 143.5 (43.5% firmer than Factory)
#6 = 172 (72% firmer than Factory)
#7 = 197.5 (97.5 firmer than Factory)
#8 = 223 (123 % firmerthan Factory)
lower than 2, 1~8 no lower than 4." -Club 3G
all i wanted was the 223% stiffer ride. but not damage anything.
it says not to go past 2 and 4. i want to know why.
is it that its bad for the struts to go to 4 and 8? or is it bad for the springs?
My ride:
2002 ZX-6R
CH-53E
Want to get:
2008 6R or 10R
Evo VIII or
STi
Old 03-23-2006, 01:31 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: suspension
It probably isnt that its bad for the spring/strut, its that the ride may be so stiff that it might damage critical driveline/wheel hub parts. Think about it. If something has very little give where it is supposed to, and that is the only reinforced part, it will give somewhere else. And honestly, why do you want your car to ride like shit all the time. At the track maybe, but on the street...come on, dont kid yourself.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 03-23-2006, 01:13 PM
Re: suspension
i guess your right man, it's just not very pratical or good for the car. i guess i'll get the agx and the pro-line. well where i live there are really really good streets and roads there won't be that much stress.
this just in..."When using Eibach Prokit springs recommended setting on a 1~4 is no lower than 2, 1~8 no lower than 4."- meaning the springs need to be changed. might i be right on this?
My ride:
2002 ZX-6R
CH-53E
Want to get:
2008 6R or 10R
Evo VIII or
STi
Old 03-23-2006, 06:17 PM
Re: suspension
my friend ran his on 4 the enitre time with no problems (note:he also track raced it )
every thing was stock other than hi clutch intake exhaust and suspention so keeping it at the stiffist ist a problem as for our car though they only make the 4way for it not the 8.
agx's will work with ALL springs (if they are factory replacments,ie:will fit on the stock struts.)
Old 03-23-2006, 07:28 PM
Re: suspension
thats alright about the 8 pos. one not being made for out cars. setting 4 and 8 are the same percentage (%223 stiffer). and i even have the fact that i have really good streets on my side. there was a guy on club 3g with the 8 pos. agx... if i recall. sooo good streets = good ride.
My ride:
2002 ZX-6R
CH-53E
Want to get:
2008 6R or 10R
Evo VIII or
STi
