Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 03-20-2006, 11:12 AM
myk3 myk3 is offline
97 mirage wire colors
the previous owner of my 97 mirage ls cut up the harness... does anyone know the wire colors so i can install my new aftermarket cd player? (the speaker wires may have been changed, but i can always trace those back to the speakers... i basically just need to know the power, and ignition(?) wires....) thanks im kinda new to this
Old 03-22-2006, 04:21 PM
twisted_intentions twisted_intentions is offline
Send a message via AIM to twisted_intentions Send a message via Yahoo to twisted_intentions
Re: 97 mirage wire colors
a Wire Tester Would help u out alot...
Old 03-22-2006, 04:23 PM
Thumbs up Re: 97 mirage wire colors
a Wire Tester Would help u out alot...while the car is off put it on the wire that lights up-wire that to ur 12v main wire on radio...turn the key to acc.. check the wires again...if it lights up connect the Ign+ wire on the radio to it..Black is ur gound...And BAM..u got a workin radio....wire tester is only like 10 bux
Old 03-22-2006, 09:39 PM
is there another name for it other than wire tester? could u post link? could i get one at home deopt or autozone mebe?
Old 03-24-2006, 09:54 AM
DFBonnett DFBonnett is offline
Do a Google on automotive circuit tester. Lots of pictures so you'll know what it looks like in the store.
Old 03-28-2006, 11:59 PM
thanks everything works!!!
Old 03-30-2006, 11:40 AM
... kinda!!!
my stereo doesn't save my settings... could it be my 12v main and IGN wire are switched...?
when i tested with the circuit tester, niether wire had power, turned to ACC and both had power, started car and both had power...
is there mabey a third power wire?
