Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-20-2006, 10:57 AM
terpsfan88 terpsfan88 is offline
93 super coupe manual tranny shifting
i Have a 93 super coupe and i think there might be a problem with the tranny. when i first start to drive it, shifting is easy and smooth. but as i drive it more like an hour or so i can still shift into gear but it seems like there is alot more resistance to make it go into gear than when i start driving in the beggining of the day. if i stop somewhere for a couple hours then start to drive again the tranny shift fine. i seems like if i drive for longer times the tranny gives me more resistance. any help is appreciated.
Old 03-20-2006, 11:53 AM
C. Cleve C. Cleve is offline
Re: 93 super coupe manual tranny shifting
Hi, This may sound stupid, BUT have you checked the trans fluid lately????????????????????????..
Old 03-20-2006, 03:50 PM
that doesnt sound stupid at all, i was just going to get it changed on wensday and see what happens. i just wanted to post my problem to get the jist of what it might be...... but ill post another reply after i get the fluid changed...... thanks alot.....
Old 03-20-2006, 04:22 PM
yea i just went and tryed to check the tranny fluid but couldnt find any anything dipstick for the tranny. my manual doesnt give and description for where to check for fluid for the manual tranny just where to check for the clutch fluid.... you have any idea how i could check it??????
Old 03-21-2006, 12:28 AM
intrcptrbird intrcptrbird is offline
Send a message via AIM to intrcptrbird
Im not sure about that particular tranny but the one one the ranger I used to have that had a 2.9L V6 with a manual didnt have a dip stick but an oil level check screw on the side of the tranny. After you pull out the screw you'd simply fill it up fairly slowly unitl it overflows. If its that kind of tranny.
Old 03-21-2006, 06:10 PM
overl0rd overl0rd is offline
It will have a plug in the side of the tranny(there will be 2, it's the top one, should have a 3/8" square in it), you unscrew it and stick your little finger in there. If you can't feel fluid it's low, it should be within 1/4" of the top hole.
Old 04-10-2006, 12:29 PM
BigBob-O BigBob-O is offline
Send a message via AIM to BigBob-O
i had similar prob with 1990 sc and i got my trans mount replaced and the prob was gone.
Old 12-06-2007, 04:24 PM
Blacky72 Blacky72 is offline
Send a message via MSN to Blacky72
Hi There!!! i have a thunderbird sc 1989 with 3.8l and manually tranny, just some issues that i have with this tranny, firts according to the web, its say that it have this bird the tranny its M5R2 Mazda made, OK. lets say that, and i looking for one of the in ebay market and i found the same tranny or that part number M5R2 is used in f150 and f250 ford truck, can be posible???
bay the way im having problemes with the original of my bird in the 2 speed.
Thanks in advance!!!!
Old 12-06-2007, 04:53 PM
TeamExploder TeamExploder is offline
Send a message via AIM to TeamExploder
It could be possible it's just the tranny gear ratio's probably different and probably stronger made....Not really sure, as to the dipstick thing, some car manufactures believed you would never have to change or check your tranny fluid so some tranny's they didn't provide a dipstick with.
1996 Explorer XLT 4X4 Auto. 4.0 OHV BWM to Fulltime and auto 4X4
1999 Malibu. 2.4L DOHC Auto
2000 Explorer XLT 4X4 Auto 4.0 SOHC
