Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 03-20-2006, 11:40 AM
n8zdogg n8zdogg is offline
Noisy belt??
i have a new (surprised?) problem with 2001 5.9. After the engine warms up (slower idle) the belt squeaks. As soon as I touch the gas, the squeaking stops. I've tried STP belt spray lube which works for a few minutes and then the problem returns. Any ideas?
Old 03-20-2006, 11:15 PM
jdq jdq is offline
Re: Noisy belt??
change it
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 07-25-2006, 01:44 PM
acoelho00 acoelho00 is offline
Send a message via AIM to acoelho00 Send a message via Yahoo to acoelho00
Re: Noisy belt??
I have a 99 Durango 5.2. I also have a noisy belt but mine squeaks on higher RPMs. Tried belt dressing (works temporarily) I replaced tensioner pulley cause old one was not springing back on its own. The sqeak is still there. My neighbor said to use a bar of soap on the serpentine belt wile it was running and it did take the noise away better than the belt dressing. After a few hours of driving it again came back squeaking. The belt is new. I need Help TOO!!!
Old 07-25-2006, 08:57 PM
Brandonman38 Brandonman38 is offline
Re: Noisy belt??
try it with ivory soap
sound stupid but thats what i have always used because i was told it dosnt work as well with anyother soap
Old 07-27-2006, 08:29 PM
Re: Noisy belt??
Thanks Brandonman38
Old 07-31-2006, 03:34 PM
steelerguy steelerguy is offline
Re: Noisy belt??
It's not clear to me that you have changed the belt. You should if you haven't already. They don't last forever & it's often hard to tell if they're worn. A squeal would be an indicator of a worn out belt.
If the belt breaks, the engine keeps running though you will get an overtemp indication as your water pump that cools your engine has stopped turning without the belt.
You will destroy your engine if you keep driving for even a few minutes.
Old 07-31-2006, 06:01 PM
Re: Noisy belt??
I Just found out today that my squeaky noise was from a technician who installed my power steering pulley too far in which missaligned my belt that was also causing it to wear out on one edge also. SQUEAK SOLVED!!!
