Old 03-20-2006, 09:08 AM
SIDMAN SIDMAN is offline
How Do I Retrieve Transmission Codes
I have a 4l80e transmission and it won't shift out of second. I heard that it could be a shift solenoid or ignition switch so i want to check for codes. I used a scan tool on the typical connector but it didn't find any codes. Is there a different connector for transmission codes? If you could please instruct me on how to check codes as if I was stupid so I can be sure i did it right. Thanks, all help and info os appreciated.
Sidman
Old 03-20-2006, 02:16 PM
2000CAYukon 2000CAYukon is offline
Re: How Do I Retrieve Transmission Codes
There is only one connector to read codes. Some scan tools only read generic codes and will not include "enhanced" codes (such as ones that the transmission will set).
Which scan tool did you use? Perhaps you can contact the scan tool company to see if they support trouble codes for your 4L80E.
//2000CAYukon
Old 03-21-2006, 10:17 PM
I tried to retreive the codes using an Actron OBD2 decoder (cost around 150.00). Nothing came up. I did test for power to the solenoid so i think since it has power it must be the solenoid or something worse. It will not shift out of second no matter where the shifter is. The tranny was just rebuilt and this is first time trying to drive it since i put it in. If anyone has instructions, please post or explain it.
Thanks
Sidman
Old 03-22-2006, 06:02 PM
I have read that if you install the valve body bolts wrong, it can stick in 2nd gear.
There are also 2 shift solenoids, did you check that both are working?
//2000CAYukon
Old 03-27-2006, 02:28 PM
chevrods chevrods is offline
i just had this problem with a turbo 400...is your reverse kinda sluggish and doesnt move fast unless u punch it?
Old 03-31-2006, 12:26 PM
just to let you know i pulled the pan to replace shift solenoid and i found the electrical plug disconnected on the shift selector switch.
All fixed now
Thanks for the help
Sidman
