Old 07-06-2002, 10:07 PM
Dudley03 Dudley03 is offline
1/4 panel question
hey has anyone had to replace a rear quarter panel and if so did you do it yourself? how much did it cost, was it hard, etc...?
thanks
Old 07-07-2002, 08:15 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
They have to be welded in since they are attached to the frame. I heard someone say $900 once but I am hoping that is for both sides and not just one.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-07-2002, 09:50 AM
jc836 jc836 is offline
I recently estimated this at my body shop and they want over $1100 per side including everything. The Honda panels go for around $500. This is a job that requires some very careful work as it is a stressed member. To really do it right means cutting the panel off so that the new one fits into the hatch lip area. You are also looking at having some metalwork done to the inner panels as part of this. There are shops that can do it for less-just make sure they are properly equipped.
Old 07-07-2002, 10:24 AM
You don't need to replace the whole panel. Most if not all rust will be found right at the bottom of the fender. And there is enough room there to cut that off then weld in a new piece. I saw on hondaautomotiveparts.com they make a very small section of the rear fender now I guess because rust there is so common, so you don't have to buy the whole huge panel.
And for $1100 a side I would rather get a new Civic than saved my rusty one.
Old 07-07-2002, 03:08 PM
My reply is based on the worst case. I agree that partial panels are readily available and if done right will last. Whatever one does-if the car has a sunroof, do make sure that it is draining properly.
I was about to buy a car that needed this work done and agree that if the panel and under pieces are real bad, you may well be considering another direction.
Grandpa toys-Modded suspensions and other tweaks
'89 CRX Si PDA/NASA/SCCA/Steel Cities ITA pocket rocket
'99 Prelude Base SS - A Sweet Song in Motion
'03 Dodge Dakota Club Cab-gonna tow the CRX
4 runner fiberglass 1/4 panels ... installed slacker501 4Runner/GX470 0 11-02-2004 11:29 PM
94 Explorer Xlt Rear 1/4 panel fijron Explorer | Explorer Sport Trac 0 10-16-2004 06:42 PM
replacing rear 1/4 panels?? fiercecivic '88 - '91 Civic | CRX | Wagon | Shuttlee 3 02-03-2003 07:17 AM
NEEDED TO BUY!!! Front 1/4 panel TIZAO Classifieds 12 05-02-2002 11:22 AM
1/4 panel removal question Veil_Side_ '71-'87 Civic | CRX 1 01-14-2002 02:19 PM
