Old 03-20-2006, 02:36 AM
dixieonly dixieonly is offline
'98 Pontiac Grand Prix GTP Coupe - Passenger Door Cannot Be opened anymore
Door locks and unlocks, it also can be opened a little bit from the inside and the outside but then it is blocked. The gap between the door and the frame is to narrow I could reach the locking mechanism. What can I do? Appreciate any help. Thanks a lot.
Old 03-20-2006, 06:37 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: '98 Pontiac Grand Prix GTP Coupe - Passenger Door Cannot Be opened anymore
The door is adjustable at the hinges and can be moved forward if necessary by loosening them and moving the door slightly toward the fender. You will need to loosen both upper and lower hinges to move the door. I recommend that you leave them snug so that you can move them just a little at a time. Of course you will need to get the door open to do this. Make sure to support the door fully and not to move it too far when adjusting it. This should cure the clearance problem.
