Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-19-2006, 09:47 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Fmic installed few problems... but looking nice
Okay, well I started this task 2 weeks ago. I had 3 days set aside to finish this install but, on the second day I woke up with a fever of 103. Anyway, 2 weeks later and about 15 hours of actual work later it is done. This was my first real "big" project on my car so it took a little longer than it takes most people. However, I ran into the most dumb problems you can think of...only on a dsm.
First, one of the bolts holding the bumper on right by the hood latch was stripped so it wouldn't come off so that took a lot of time cutting it off.
Second, the piping that came with the kit I thought was going to be aluminum but, appartently it is freakin steal. While trying to drill holes for my damn bov flange It took 2 broken drill bits untill I borrowed a drill press from a friend.
Third, I have a T28 turbo so of course the outlet faces the passenger side. I was just going to have the turbo elbow cut and just rig the piping up but, I wasn't confident in cutting my turbo... So I ended up using some of the old piping and doing a 180 degree bend under the turbo back over the to the intercooler piping. I do not feel confident with the old piping mostly because I plan on running 20psi in a week or so.
Fourth, of course the overflow bottle wasn't fitting back where it was. This wasn't that big of a deal because I just mounted it in the wheel well where the old smic was. However, when reinstalling it the (rusted)wires that go through the plug that goes into the bottom of the bottle pretty much snapped in half. So, now I have a nifty check engine light on. I am almost positive that this is the cause but, once I figure out how to fix it I will know for sure.
Okay, so I got it all on and was running 15 pounds of boost on my T28 "50 trim" and it didn't take long to hit fuel cut. I have 650cc injectors sitting beside me as I am typing but, I need a fuel pressure reg. As soon as I order that I will install the injectors along with it and hopefully be able to run 20pounds of boost. I am about to start playing with my pocket logger and afc(I have spent at least an hour on reading how to tune it) Anyway I have gotten lots of comments on the intercooler by people who know what it is but others are like "That performance radiator is pretty shiney!" Okay, so that is my life story haha. I will be posting pictures up as soon as I can. Oh and if anyone was wondering this is the fmic from the group buy from ssautochrome.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 03-19-2006, 09:53 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Fmic installed few problems... but looking nice
My wires broke on my overflow bottle too, but I didn't get a cel. Take it to autozone if you don't have a logger yet.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-19-2006, 10:05 PM
NateS's Avatar
Alright, I will deffinatly do that. OH, and thank you again for the extra "coupler" for the gap in the piping. It worked beautifuly.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 03-19-2006, 11:42 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
You either have a T28 or a 50 trim. To my knowledge, there is no T28 turbo that could have the ratio of a 50 trim.
now - 2000 civic
soon - 2002 is300
Old 03-19-2006, 11:49 PM
ez1286's Avatar
just out of curiosity did you do a boost leakdown test after the install? That could cause you fuel cut problem.
Old 03-20-2006, 08:31 PM
NateS's Avatar
Kevin posted this in one of my other threads. I guess you did not see it.
"Remember that the trim of the turbo is not the size, just the ratio of some of the dimensions. You could have a very small wheel like a t28 be a 50 trim, just not "the" 50 trim
At any rate, the t28 is somewhere around the size of a 14b. I think the highest airflow I heard logged was something like 32-34 lbs. So you could treat it as such. 20 psi should be doable. I would just keep raising boost until it knocks or stops increasing in peak airflow."
As for the boost leak test, no I have not had the chance to do a boost leak test. Recently I have had school all day then leave school and go straight to work. So I have not had the time but, I will be building a boost leak tester as soon as I get the time.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 03-20-2006, 09:10 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Originally Posted by Just a GSX fan
At any rate, the t28 is somewhere around the size of a 14b..
Notice the size diffrences' between the TDO5H housing's and the T-28? And the Compressor size diffrence in theT-28 and 16g's..
http://www.vfaq.com/mods/Turbo-compare.html
You can see why it's a easy stock replacement, its exducer wheel is really small, makig it spool supper quick.. but it compressor is almost matched to the Small 16g. I personaly don't see the potentual in it, And would rather spend $60 on a good used 14b..
Old 03-20-2006, 09:37 PM
NateS's Avatar
Honestly, I don't either. I am not posting saying my turbo is the shit. I in no way think so. Personally, I would rather have a 16g myself. The car came with the turbo in it so, that is what I will have untill I get enough money and supporting mods to put a new turbo in it. I don't wont people to think I am "talking up" my turbo. It is what it is.
Oh and that was what kevin posted in a previous thread. (notice quotation marks)
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
