Old 03-19-2006, 10:39 PM
jeter1955 jeter1955 is offline
4L60E Trans Problem
I have a 94 camaro z28 and cant figure out why its having a problem shifting into fourth. It wont shift into 4th gear unless im doing around 50 and i take my foot off the gas, when i put my foot back on the gas it will be in 4th. could this have anything to do with the tourque converter. maybe 4th gear sylonoid. if this is the case, is it easy to replace or do i have to pull the trans. thanks for the help. also the trans seems sluggish with other gear shifts too.
Old 03-19-2006, 11:00 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: 4L60E Trans Problem
sounds like it is slipping and needs a rebuild, first try to do a flush and filter and add some of that lucas to it. See what happens then.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 03-20-2006, 01:59 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Torque convertor - Very doubtful
Solenoid - slightly doubtful
Slipping - Uh, uh
I would guess that it has more to do with a bad seal somewhere, not letting the trans. build up enough pressure to shift it into OD (4th). Probably needs to be rebuilt, take it to a pro less headache.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 03-20-2006, 09:29 AM
thanks for ur help, but it doesnt slip at all, i can gun it and abuse the hell out of it without it slipping, any other suggestions?
Old 03-20-2006, 09:56 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Probably because you have been gunning and abusing the hell out of it that it needs a rebuild..
Take it to a trans pro.
Old 03-20-2006, 12:50 PM
malletslinger's Avatar
malletslinger malletslinger is offline
Yes...take it to a trustable trans shop and ask if someone will take a test drive with you...
If you live in SoCal, I recommend LEON'S...
Otherwise ask around your area to find a good trans shop.
Old 03-22-2006, 08:49 AM
what are the shift points for this trans?
mine goes into lock up at like 45-50
and shifts into 4th at like 55-60
is this normal.
the shift points change with the amount of throttle
could a bad VSS make it shift at wrong points?
Old 03-22-2006, 09:29 AM
The shift points do change with the amount of throttle, and what the heck is lock up?
2006 Hyundai Sonata
Old 03-22-2006, 10:35 AM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
lol, hell man yours is doing what mines was doing a while ago, now mines is gone.....getting a new tranny as we speak. 3rd went out all together last sat. get it fixed before it leaves u on the side of the road.
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 03-23-2006, 05:22 PM
BLAZINGZ28 BLAZINGZ28 is offline
I just had mine rebuilt and it wasn't cheap but now i know it could handle some torque. you should get it repaired before u get left stranded somewhere.
1995 PONTIAC TRANS AM LT1 6SPEED.
