Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-19-2006, 09:40 AM
food4me food4me is offline
Send a message via AIM to food4me
can i cut this?
I wanna put a new cam in my 87' 150 i really don't feel like pulling th motor just to put in a new cam but there is a vertical bar in the way. it is on the front of the body. is it ok to cut this bar off then weld it back on after the installation?
Old 03-19-2006, 08:10 PM
dadof4s dadof4s is offline
Send a message via AIM to dadof4s Send a message via Yahoo to dadof4s
Re: can i cut this?
I think hat I would pull the motor.
Old 03-19-2006, 08:35 PM
Re: can i cut this?
i know but this just seems soo much easyer and less time consuming
Old 03-20-2006, 12:42 AM
tony36 tony36 is offline
Send a message via MSN to tony36
Re: can i cut this?
No do not cut the swaybar. They are made for a specific amount of flex and if you heat them it will take that out. Pull the motor, it only takes a couple hours and will save you more time than trying to change out the cam in the truck.
Old 03-20-2006, 01:12 AM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Re: can i cut this?
Spend a little more time on it now....or spend more time AND money down the road. Simply choice for 95% of the people out there.
Pictures of the Truck
Old 03-20-2006, 08:43 AM
slantsixness's Avatar
slantsixness slantsixness is offline
Re: can i cut this?
I'm not getting this:
"I wanna put a new cam in my 87' 150 i really don't feel like pulling th motor just to put in a new cam but there is a vertical bar in the way. it is on the front of the body. is it ok to cut this bar off then weld it back on after the installation?"
What motor, a 225, 318 or 360? this is an '87? so.... what's in the way that doesn't unbolt?
The SWAY BAR? You all are way off track! He said CAM not CRANK!
Food4Me:
The vertical bar is the center support brace on the radiator support. Yes, you can cut it and then put it back. On some years, it actually unbolts from the top or bottom, but have a look for yourself.
If you're not going to rebuild it, at least use new lifters, and check your pushrods for being straight (roll them all across a flat table...) and rocker arms for wear (looseness on the shaft, worn pushrod dimple, clogged lube hole.)
Good luck.
Tom
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 03-20-2006, 08:41 PM
Re: can i cut this?
255? no. 318? no. 360? no. 500 yup a 500 out of a cadillac feeltwood. i know im gonna get some people angry at me for it not being mopar. sorry im too cheap to buy a new big block and i couldn't find any
the only thing in the way besides the bar is radiator and grill
