Old 07-06-2002, 04:25 PM
sircivic sircivic is offline
b18c1 swap help
I know this is a little bitchy to ask, but i need to get this motor running in my 93 civic ex asap. I got the 95' b18c1 to fit in perfectly, the axels I have gotten in, the modded shifter linkage, but damn it, i'm having problems still! most of the electronics plugged right in, no prob, but i was looking for a general overview of how to hook this thing up, and the parts i need to do this. please help! thanks
Old 07-08-2002, 10:47 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
Well what else do you need? Is it just electrical or some mechanical. I hope you do know you need to run some wires to the sensors straight from the sensor to the ecu or get a hasport harness. I got a modded shift linkage in mine and i hate it! You pop it in gear and you can swing it left to right about as good from 1st to 2nd. I would get a hasport or HCP shift linkage but if its just a quick fix then you are okay.
VTEC WORKING FINALLY & HAULIN SOME ASS!!
If the shadow of your car is smokin' you it definately means you are smokin' someone else!!
KKK k24 Turbo on the way to the install!
Old 07-10-2002, 10:57 AM
hey thanks for the info man, i knew about the knock sensor, but that was all I was told to wire up...and the other stuff is coming along nicely now. i'll be sure to call hasport and get their professional opinion like you said. thanks
Old 07-10-2002, 11:15 AM
S2Corolla S2Corolla is offline
Send a message via AIM to S2Corolla
nemesis_2000 has this swap done, ask him about it. I don't know if him and his friends did it or if he got it done at a shop though so don't expect all your answers given.
There is a lot of wiring. do you have all the vtec wires connected?
Team S2
0-60 = 7.3
1/4 Mile = 15.5
Current Mods: P&P head, custom cold air intake.
Old 10-15-2002, 08:50 AM
LX98Civic's Avatar
LX98Civic LX98Civic is offline
Send a message via Yahoo to LX98Civic
Yes, he bought the car with the swap already done. But, I will doing the same swap he has and nemesis_2000 will be helping out along with civickid77. I have to find the h/b first which I am going to be looking hard today.....
I found this web site to be a lot of help since it's pretty detailed and has pictures as well:
http://www.c-speedracing.com/howto/b18cswap/swap.html
Lots of how to's for the B18C:
http://www.c-speedracing.com/howto.html
sircivic: How hard was the swap? Did you ever get it running? What was the problem? This will be my first attempt on major engine work, but I am looking forward to it. Looks pretty straight forward and I'll have the digital camera on hand snapping away and posting when I run into problems
Thanks!
---------------------LX98Civic ---------------- nemesls_2000 ------- civickid77----------------
--- --- --- -- Sleeper in the middle -- --- --- ---
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
B18C1 CR-V Swap Help n_i_c_k How-To's and Walk-Through's 0 04-27-2009 10:54 PM
b18c1 swap in civic help???? jacer Let's get Technical! 2 01-19-2004 12:01 PM
b18c1 swap in 93 civic sircivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 06-27-2002 02:44 PM
b18c1 swap JDM wiring? SFF900 Engineering/ Technical 1 02-02-2002 02:34 AM
