Old 03-19-2006, 12:59 AM
OffRoadSonoma's Avatar
OffRoadSonoma OffRoadSonoma is offline
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
Amp inside box??
I have an extended cab s-10 and am going to be building my new box. I'm looking around 6ft^3 so it doesn't leave me with much room behing the seat. So I was thinking about bundleing the power, ground and remote and just running them through the box and mounting the amp inside the box to save on space and look cleaner. So I pretty much just wanna know if this will damage the speaker or amp or if it will be more likely to overheat. So far the amp barely gets warm to the touch and I push it pretty hard, but then again it is 20 degrees outside. So do you guys think that will work or should I mount it somewhere else?
Old 03-19-2006, 01:13 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Amp inside box??
I think it would be much easier to just mount the amp under the driver or passenger seat and run the cables there then to try to do all of the work necessary to run a large power cable through the enclosure wall without leaks.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-19-2006, 09:51 AM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Another thing to think about is if you do mount it inside the box how will you adjust the gains and other controls on the amp when you need to. Besides that if it's a sealed enclosure there will be no air movement inside the box allowing the amp AND sub to get extremely hot, even if the box is ported there will still be minimal air movement by the amp and it will still likely overheat. Like sr20 said mount it under one of the front seat if that won't work then build a panel for it to mount to in place of one of the back flip down seats on the side.
Old 03-19-2006, 08:47 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
putting the amp inside the box is not really a workable solution ...... as stated above, the extra heat, inability to adjust and having to run wires into the box make it a VERY poor choice. I would mount it TO the box if you have to.
Old 03-19-2006, 11:27 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Don't do it.
nG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 03-20-2006, 08:38 AM
Looks like that settles that.
