Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-19-2006, 12:46 AM
94 prelude si 94 prelude si is offline
vtec h22 head fit a h23 block
does a vtec h22 head fit a h23 block???
Old 03-19-2006, 09:29 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: vtec h22 head fit a h23 block
Yes, you will need to change a few things though.
1. VTEC head, complete: cams, gears, rockers, valve cover.
2. VTEC timing belt- VTEC has more teeth on the belt than the Si does.
3. VTEC water pump.
4. VTEC auto hydraulic tensioner for timing belt.
5. VTEC manual tensioner.
6. VTEC head gasket.
7. VTEC lower, most inner crankshaft pulley;
8. VTEC intake manifold
9. VTEC exhaust manifold - i couldnt find a used downpipe, dealer was $621, so i bought DC Headers-VTEC.
10. VTEC ECU/ECM.
11. VTEC spark plugs and wires.
12. VTEC water pump pipe (black pipe that runs behind the head from the water pump to thermostat housing.
*DISTRIBUTOR should be the sames, so it shouldnt need to be changed - double checked part numbers.
*VTEC controller - not required but could be used if you dont buy a new ECU/ECM and have a way to bypass your redline.
The reason for changing some of parts listed is because the VTEC timing belt has more teeth on it that the Si belt. Therefore you need to change everything that touches the timing belt such as the inner most crankshaft pulley, tensioners, and water pump- because you dont want to have to go back in there a few months down the road if it goes bad and starts leaking and open everything back up to change it. Change the lower balancer belt as well for the same reason as the water pump, however it does not need to be converted over to the VTEC part. The timing belt doesnt touch the balancer components on the lower block so nothing had to be modified with that, only what touches the timing belt.
Old 04-04-2006, 07:23 PM
gearnuts gearnuts is offline
I agree with everything you said up there except for the auto tensioner. The auto tensioner that comes with the VTEC is known to give problems. And the solution is to use the manual tensioner from the H23. It works if you use a couple washers as spacers and such. There are write-ups all over the internet for it. Thats just my
Old 04-04-2006, 08:33 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
^ I agree
Old 04-05-2006, 12:20 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Look on honda-tech theres a few wrietups on the h23/h22, and f-series blocks with h series heads. The h23/h22 combo is what im working on now proving a little tough but so far so good. Still need a damn head.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
