Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 03-18-2006, 11:10 PM
sprucegoose's Avatar
sprucegoose sprucegoose is offline
Question Turn signal indicator light??
Recently I noticed that my right turn signal arrow indicator on the dash was lit (continious) while I was diving along. This is only after dusk when the headlights are on, it goes away during the day...
At first I thought it was because I had a burned out left front running lamp, because this also alternately flashes when you have your turn sinal on. So I replaced that bulb today... PIA to remove all that plastic shroud in the wheel-well just to get at a stupid bulb! Now I still the same glowing right green arrow on the dash!!
I know, I know... Here I am griping about a stupid indicator lamp, when others are having problem just keeping there cars running! I am very grateful mine runs like a scalded cat, but it drives me nuts seeing this lamp stuck on and not knowing why. All the other lights, signals, etc. are all working great, what can cause this??
~Dave~
'08 Chevy HHR SS, Victory Red, 5 spd. 2.0L Turbo, 52K mi.
'98 Buick Riviera, Black, 3.8L Super-Charged, 228K mi.
'98 Chevy Tahoe LT, 5.7 Vortec, Black 241K mi.
'70 Pontiac Firebird Formula 400, 4spd 200k+ mi., in process restoration
'10 Dodge Grand Caravan SE, 11K mi.
Old 03-18-2006, 11:29 PM
frankvega93 frankvega93 is offline
Send a message via MSN to frankvega93
Re: Turn signal indicator light??
you have a short wire that is conected to front or rear signal lamp easy if you check the the filament of the bulb is touching shortlight change both bulbs and see if the wires are together good luck pal
Old 03-20-2006, 08:21 PM
Unhappy Re: Turn signal indicator light??
Woah! That's one heck of a sentence there! I think I have de-coded it though...
I checked for a bad bulb or short in the rear tonight, found nothing wrong back there. Switched all the bulbs from the other side, still acts the same. Major pain getting at those also. 10+ fasteners to pull that whole rear tailight panel off!!
I want to get to the bottom of this soon because now the right signal isn't flashing about 50% of the time. On the way into work this morning I noticed this. The lamps still all light though, so I have to do the manual on/off with the signal stalk lever.... I guess I'll have to pull the front right next.
~Dave~
Old 03-21-2006, 01:40 AM
ilgoldstein's Avatar
ilgoldstein ilgoldstein is offline
My bet is that you will find a bad bulb in the front. I think that the previous poster was trying to explain that in the bulbs with two filiments, when one blows, it sometimes shorts across the other, causing screwy results. The driving light filiment is shorted against a piece of the turn signal filiment, to when it lights, current from the turn signal circuit flows through it.
I have a reoccuring problem with my 64 Malibu tailamps. One tail light goes out when you brake! Caused by a bad ground.
1995 Buick Roadmaster Sedan
1989 Cadillac Sedan De Ville
1964 Chevrovet Malibu SS
Old 03-25-2006, 06:45 PM
Thumbs up Re: Turn signal indicator light??
You are correct sir! Changed out the right front bulb today, and it is working great now. It actually started flashing again once I removed the socket, but I replaced the bulb anyway just to be sure it stays working...
Good luck with the short in the 64 Malibu tailights. Thanks again for the help guys!
~Dave~
