| Off-Topic Talk about anything other than cars. |
a mechanic told me i could remove some of my vaccum lines being i dont have emisions and all that stupid stuff and it would help me out and my engine.
i searched and couldnt find a write up of what to remove. if anyone can help me that would be good |
Re: vaccum lines
You still don't have your car in your sig. You can replace egr valve with a block off plate. That will get rid of some lines, but leave the egr solenoid plugged in. Then there's the big charcoal canister debate. Just don't unplug your fpr vac line.
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! |
Re: vaccum lines
i have the egr block off already, i heard you can take the vaccum lines off the throttle body completely cause they are just for emissions.
and i updated my sig how is that
1992 eagle talon tsi awd xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit |
Re: vaccum lines
I have almost all my vac lines off my eclipse. All I have now are for the manual boost controller, boost gauge, and fpr. Everything else is not needed. There is a write on some site, I'll look but i can't remember where it was.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
