Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 03-18-2006, 09:59 PM
marshalltlaw marshalltlaw is offline
Angry 1989 daytona shelby z coil problem
no spark , checked power at coil ,only have cranking power but on both sides but not from wire
Old 03-20-2006, 08:58 AM
slantsixness's Avatar
slantsixness slantsixness is offline
Re: 1989 daytona shelby z coil problem
"only have cranking power but on both sides but not from wire"
Please explain.
There should be 12V on the + side of the coil. there should be a pulse on the - side of the coil. with the 12V and pulse, you will have spark, or your coil is bad or even you coil wire is shorted to ground (coild would get hot).
There is a pickup coil in the distributor that will go bad, but that's just one of about 20 things I can think of that'll keep a 2.2/2.5 or 3.0 V6....from starting.
Tom
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
