Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-18-2006, 08:42 PM
trs's Avatar
trs trs is offline
question
i have a 2000 sunfire, 2.2l, 4 door. It has 118,000 km on it. what can i do to help my gas milage because i am burning alot of it, i need to fill up every second day. my second question is is it possable to adjust the cable from my gas peddle to my throtlebody, it seem to lag in acceleration?
Thanks
Thomas
Old 03-19-2006, 07:57 AM
batman13's Avatar
batman13 batman13 is offline
Re: question
how much driving do you do!?
i've got the same car but with a 2.4l
(same color too)
i can go a week with 1/4 of a tank
Adjusting a cable won't do much, if anything.
are you sure you don't have a leak?
But if you want to try the cable, The connections are located inside a small black box, about 3" by 1.5" you have to take the cover off, mine is located at the front of the engine right in the middle. the cable on the right, turns the TB, the one on your left pulls from the pedal. be careful, the adjust nut is plastic and will break, its designed so it won't move, you need to pull the locking piece away from the threads and then you can turn it CAREFULLY if you break the little peice off, the nut will keep coming loose and needs to be replaced
Good luck
'97 Dakota "Fearless"
'00 Sunfire "Ninja"
Old 03-19-2006, 08:47 PM
trs's Avatar
trs trs is offline
Re: question
i do alot of highway driving doing about 130km/h. i do not have a gas leak either, i burn a 1/4 of a tank going to work which is about 50 km from where i live. i was also told to check my o2 sensors, is there a way i can check them to see if they are working right.
tommyboy
Old 03-19-2006, 09:32 PM
BlasZ24 BlasZ24 is offline
Re: question
You only get 200km on a tank!?!?!?! My 2.4L gets 200km on 16 litres of gas so you are doing really bad, you might want to take that to a mechanic that sounds like you are pissing gas out the tail pipe if you burn through it that fast...
Old 03-19-2006, 09:51 PM
trs's Avatar
trs trs is offline
Re: question
i like drive 300 km to work every week, only work 3 day weeks, and it cast me 40.00 for 3 days, if i was burning that much gas would the car act different, or i am just thinking that it is either too lean or too rich. i changed the spark plugs like 5 monthes ago and have a k&n air filter. don't like to any shopes because they rip you off most of the time saying you need this and you need that. that is my last resort is to take it to a shop. just give me some ideas that i can try to see if i can inprove it some how, oh ya forgot if i put it on cruse control i don't burn as much gas, with out it, it goes quick and the reasion i asked about the cble to the gas peddle is because sometimes it hasates at start and some times it pick up good. well i am open for any ideas
thanks
tommyboy
Old 03-20-2006, 08:37 AM
|WYG|SS |WYG|SS is offline
Re: question
i would say check o2 sensor too but their is one right when the exhaust comes out of the engine an their should be another one after the catalitci converter. i would change fuel filter. when filling up has the car been taking less gas everytime casue ur sensor might be reading wrong?
Old 03-20-2006, 05:08 PM
batman13's Avatar
Re: question
even if your car was running too rich you wouldn't burn that much gas your engine would flood, I don't think a faulty O2 would cause that much of a gas problem. These things are hard to diagnose on-line. as for your cable, I think there is something else causing the hesitation,
another thing, how are your RPM's? are they higher than normal?
I will agree with blasz24, it sounds like your gas is going in the out pipe
what does your exaust smoke look like? if it isn't thin white that could be an indication. the thicker the smoke, the more gas is being burned.
Blue--bad,
red--your car is possesed.
green--there's another car isn't there?
clear--you stalled
'00 Sunfire "Ninja"
Old 03-20-2006, 08:21 PM
trs's Avatar
trs trs is offline
Re: question
my rpms are like at 120 km/h is 2500, the smoke that comes out is white but not alot does and it cast the same every time i fill up and almost get the same amount of leaters everytime.. full filter was changed last year and also have fuel system cleaned out. did i say that it was automatic . someone also to me that if my air intake valve is dirty it would cause some problems.
well keep nameing stuff and i will answer , lol
thanks
tommyboy
Old 03-21-2006, 11:29 AM
muff34 muff34 is offline
Re: question
Change Your fuel filter (again) and air filter and OH Ya TAKE your foot out of the OIL Pan .130 KPH and 2500 Rpm .IT`s A car not a jet ....LOL
Life Is A Highway ,Enjoy The Ride
Old 03-21-2006, 04:30 PM
batman13's Avatar
Re: question
i think i've run out of ideas but my 'fire is goin to visit her mechanic
tomorrow (i think she likes him), I'll try to remember to ask him for input
'00 Sunfire "Ninja"
Old 03-23-2006, 09:08 PM
trs's Avatar
trs trs is offline
Re: question
i just found one more problem with my car, i noticed today when i pulled out my spark plugs that in cyclender No. 1 & 2, there was oil on the plugs and 3 & 4 were dry. could this be my problem and how can i fix it?
tommyboy
Old 03-26-2006, 07:33 AM
batman13's Avatar
Re: question
that could be a big problem,
fixing it however...
change the plugs, check them in a week if there is still oil on them take it to a shop, a mechanic can do a better check, and is trained to do this kind of stuff
whatever it is, its probably internal
'00 Sunfire "Ninja"
Old 04-03-2006, 01:48 PM
trs's Avatar
trs trs is offline
Re: question
ok i changed the spark plugs and they are dry now, could i have overfilled the oil or something. i noticed that all the bolts were lose on ther valve cover, i tighened them. is there a fule preasure regulator or something. i don't see and vacume leaks either, just can't figer out why i am burning so much gas for, please give me some more things to check for.
thanks
tommy
Old 04-03-2006, 04:02 PM
batman13's Avatar
Re: question
man you really have a problem.
you might want to invest in a pontiac mechanic book
(i forget the official titles)
they aren't real easy to find but if you get one for your car they detail all of the mechanical workings.
I think im fresh out of ideas but i'll let you know if i can come of with anything
'00 Sunfire "Ninja"
Old 04-05-2006, 07:32 AM
mike_05_sunfire's Avatar
mike_05_sunfire mike_05_sunfire is offline
Re: question
Only 300 km per tank on the highway - DAMN, I get around 700 km per tank on the higway with my fire. I would have the timing checked. My last vehicle (3.0L V6 - not a sunfire) had a stretched timing belt which set the timing off and it had huge lag in acceleration and burned a crap load of fuel. I replaced the belt and timed it and all solved. Hope this helps a bit.
Cheers
