Old 03-18-2006, 07:42 PM
rattles69 rattles69 is offline
Help
I have a 97 Cavalier 2.2 5 speed. I am wanting to install a gauge cluster from a Z24 cavalier 5 speed with tach. I have tried installing and the car starts and runs for like 5 seconds then dies. What would cause this and how can I fix it? Do they have a gauges cluster for the 2.2 5 speed with a tach?
Old 03-23-2006, 01:05 PM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
Re: Help
the rs has the tach 2.2L as far as using the z24 the engine wiring is differnt so you could be shorting out the coil the tach runs off the negative on the coil
1993 HONDA CIVIC EX
BLITZ FRNT M3 SIDE BLACK WIDOW REAR
JSP TERMINATOR WING
17' MOTEGI SUPER SILVER RIMS
D16Z SOHC 1.6 VTEC
SKUNK2 INTAKE MANIFOLD
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
T25 CUSTOM TURBO KIT @ 7PSI
TUBULAR MANIFOLD
AIR TO AIR INTERCOOLER
ALCOHOL INJECTION
18002 TURBO MILES AT 218002 MILES GOING 140MPH FINALLY WENT
BUT, STILL GOT ME HOME
Old 03-23-2006, 06:36 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Help
no the RS model does not come with a tach (i can say from experience) if you want a tach in a 97 cavalier that did not come with one stock, you will need whats called a "tach adaptor" since there is no single wire you can tap into for your "signal". The adaptor i have has 3 wires, 2 of the i had to splice into 2 other wires right on the coil pack, and the 3rd wire is the "signal" for the tach
sorry i cant help with your guage cluster problem/not starting problem, but i can help with installing a tach in a cavalier
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 03-23-2006, 06:51 PM
Re: Help
Thanks for the info
