Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-18-2006, 03:56 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question How much HP with head work?
Hey all;
I'm just wondering... when I get all this head work done, about how much HP am I going to be getting from it? I'm going to get the head ported (not oversized), port-matched runners IM and header, 60mm TB, port-match IM again, stock valves, probably alittle better springs and retainers, adjustable cam gears, and some basic cams. I'm not talking stage 4 cams where they cost like $1000 for one of them... just something alittle over the stock ones. What kinda power am I looking at on just the head alone? Like 20hp? I know with the intake and exhaust it'll get the full power of it. Let me know. Just a rough estimate. Thanks. Compression is going to stay the same.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-18-2006, 08:21 PM
SLoe's Avatar
SLoe SLoe is offline
Re: How much HP with head work?
Very hard to answer such a question. Depends on how good the person is whom is doing the job, how restrictive the head is in the first place, and how good the person is whom is doing the job. If you aren't changing runner, or valve size, not as much. That is OK though bigger runners aren't always a good thing. I think if the head was all you did you MIGHT see 15 or 20 IDK I'm just guessing. It sounds like you have a good plan, and you should see some nice gains. Are you going to the dyno after everything is done? I think it is interesting to hear about someone taking a non fast car and making it fast.
Good luck!!!
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 03-19-2006, 12:37 AM
david-b's Avatar
Dave is THAT guy
Yeah. It's going to be awhile before everything falls into place. This is where it gets expensive, and I'm kinda broke. But, it looks like I won't be dropping the car this summer and spending all that money on the head.
I know there's really no way to tell... I was just looking for a ballpark figure. Should I change the valve size? Would it be worth that extra money? I'm going to get the head ported somewhere else (not sure where yet) and I may be willing to spend that extra money depending on the gains we're looking at.
Something else I didn't realize too is that this head job will chnage the sound of the car alot. With cams and larger everything, it should sound like a beast.
Any ideas are very welcome here. Thanks.
75 Monte Carlo
Old 03-19-2006, 09:04 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I agree with loeman, with just the head work I think you would see about 15-20 but I think the total will be closer to 30. Just depends really. I'd love to see a dyno sheet of the difference when you are done.
1991 GSX 2.3 Stroker
Old 03-19-2006, 08:24 PM
SLoe's Avatar
I think you should contact the cam manufacturer, they can usually make some good recommendations. Everything has to work together effeciently, and you need to have a certain RPM range in mind. IMO if you don't increase runner size, and use a mild cam, then bigger valves aren't going to increase airflow that much (might even lose velocity). Definitely call the maker of the cams though, the bigger brand name cams have specialists who make recommendations. Remember, racers never buy a part just once though, and you may not be happy with the first combo you put together. Be ready to experiment with cams, and valves, and runner sizes. Keep up the good work, and keep us posted. .
Old 03-20-2006, 12:48 AM
david-b's Avatar
Dave is THAT guy
See the thing is... head work is expensive!! I don't have the money to experiment with different setups. I would just have different cars then. Remember, this car is a daily driver. I can't have any down time. That's why I bought another head, and building it on the side... then going to do a swap.
On the other hand, I found a place to port starting at $450.
http://catalog.exileracing.com/produ...c7d9264a4dc465
Is that going to be one of the best? Can a local machine shop do something like that, or is it best to have an automotive place do it. I think the second is the right answer. As you can see in the link, it can get very expensive when I start adding the parts from them too. Just the basics, I'm already looking at $1000. I don't have that kind of money. :-(
I don't know what cams I'm going to be using yet. I want something not too expensive, but yet will still get some power. I know cams make a huge difference in sound too, and I want a nice low rumble. lol. Not that important though. I don't know what to get.
I tried taking out some of the valves and guides and springs using bootlegged tools. I got 1!! Still got some work to do to clean it all up, so it gives me time to look up stuff.
75 Monte Carlo
Old 03-20-2006, 01:00 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Not to be an ass, but if you put that kind of money and work into a turbo dsm head you'd be looking at 50+hp.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-20-2006, 01:03 AM
david-b's Avatar
Dave is THAT guy
And there it was...
I was waiting for that. Totally missing my point here. Non turbo only.
75 Monte Carlo
Old 03-20-2006, 01:06 AM
ez1286's Avatar
And there it was...
Sorry couldn't help myself.
Killa's Avatar
Killa Killa is offline
david-b Im not try to be mean or something, Im down with ez1286 just say, sell your car or save up money for turbo dsm ( like me ).
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 03-20-2006, 01:09 AM
david-b's Avatar
Dave is THAT guy
Can we not turn this thread into a NA/turbo fight. I've been on this forum for a long time now... longer than alot of people here. You guys know what I'm doing. I'm not turbo-ing the car, or selling it and buying one. That's final.
75 Monte Carlo
Old 03-20-2006, 01:10 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
No way. I like what he's doing. Not many people go this far with the 420A, and I'm interested to see just what he can do with it staying N/T. I also want to see a dyno sheet once all is said and done. I will never go this far, but since you have as much money as you do invested in the car already you might as well keep going and make it the best you can.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 03-20-2006, 01:17 AM
Killa's Avatar
I forget your goal was 210whp. Keep your head up and chin down J/K. Im never own a turbo car, so Im still consider a n/t guy. good luck
GM FOR LIFE !!
95 camaro lt1
Old 03-20-2006, 08:20 AM
SLoe's Avatar
The "street" port on that site is something you could do yourself, or have a local speed shop do IMO. All they do is gasket match, 3 angle valve job, and polish the chambers. Then again if you don't trust any of your local shops, the online option is all that is left. When I said be ready to experiment, I didn't mean dump a butt-load of money in all at once . I mean if you are going to keep the car, then later down the road you might think about changes.
Cam selection is all about RPM range. Take into consideration the weight of the car, manual tranny, etc. Since it is your daily driver you will want to keep the duration fairly short, but you can get away with a little more because you are MT . You will want a broad power range for the street, so you have good torque available at any RPM point.
As for the rest of you I would like to see him continue with the N/A project. ALMOST makes me want to go get a GS and make a drag car out of it.
Old 03-20-2006, 09:58 AM
david-b's Avatar
Dave is THAT guy
What exactly is a "3-angle valve job"? or a 5?
75 Monte Carlo
