Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-18-2006, 02:14 PM
ggww ggww is offline
Out of gas!!!!!!
Son ran 2k ranger w/ 3.0l out of gas. The truck has 110k miles on it. Can get it to run by spraying carb claener in plenum while cranking. Replaced fuel filter but I can't find the fuel pump and or the relay to see if it is working. There is no fuel going to the rail did get a little air out when the schrader valve was depressed but no fuel.
Old 03-18-2006, 04:24 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Out of gas!!!!!!
Fuel pump is in tank. Go to wwwlfleet.ford.com and click on maintenance tab, then click on owners manual, enter info, go to roadside emergencies and look for the fuses and relays. It will show you where all the fuses and relays are located.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-19-2006, 12:09 AM
Crasen Crasen is offline
Make sure you check the inertia switch as well. Being that you said you ran it out of gas, you might have burned the pump up.
Old 03-19-2006, 09:46 AM
12Ounce 12Ounce is offline
I don't know why the auto designers don't just install a switch to shut down the engine when the fuel gets to an unsafe level ... or, at least, have a warning label stating the damage that may occur.
For most folks, running out of gas seems an innocent enough problem ... just refill as required!
But as the fuel level gets low, several factors are possibly involved:
. The pump fuel is designed to be submerged in fuel.
. The pump is designed to pump fuel, not air.
. If there has been trash swirling, rather harmlessly, around in the tank ... it now gets pulled into the inlet screen, and possibly the pump itself.
