Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-18-2006, 11:44 AM
blue92HB blue92HB is offline
Degreeing The Stock Cam on a SOHC ZC
As the title states I am attempting to degree the cam on my SOHC ZC Vtec engine, but I cannot seem to find any specs for the cam. Any info would be great.
Stock is Boring
Old 03-18-2006, 01:33 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Degreeing The Stock Cam on a SOHC ZC
What do you mean by degree?
Old 03-18-2006, 04:14 PM
To degree the camshaft is to insure that valve opening and closing events are in accordance with specifications. The actual opening and closing events are influenced by cam grind, belt stretch, and keyway position in the crank sprocket. What I am looking for is either cam lobe center line or degrees at which the intake and exhaust valves open and close at.
Stock is Boring
Old 03-19-2006, 09:39 AM
kris's Avatar
Makes a lot more sense that way. Just never heard of it called that before. Any factory service manual should have it. I dont have one sitting by more, I would check for you.
Old 03-19-2006, 07:58 PM
I have checked the service manual at the local dealer for the spec's on an Si cam to see if they were the same and came up with nothing at all. The only manual that I would actually trust would be the Japanese manual for this engine. So far I have not found a single thing to help with the degreeing of the cam.
Stock is Boring
Old 03-21-2006, 12:00 PM
hxgaser hxgaser is offline
I thought there was only one way that cam gear fits into the cam itself, you install it so that the key is aligned. As far as I am familiar with (which might not mean much) once you set TDC on no.1 piston, then your crank is set at the correct location for the timing belt installation. You just line up the reference markers.
Or are you asking about the actual cam lobe duration of your particular cam?
Old 03-21-2006, 03:34 PM
I am not sure what the stock duration is, but check this out.
http://www.webcamshafts.com/honda-auto.html
The values noted above seem resonable considering crane cam's street perfromance cam has 10 mm intake lift for about the same duration. But a question... only way to change the duration is to either use adjustable cam gear, which is just changing timing or to regrind. Are you really going to regrind on your own?
