Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 03-18-2006, 06:06 AM
dcolborn dcolborn is offline
Question Turn Signal Trouble
I have an 86 E150 Conversion van by Franklin Motor Coach. The other day I installed a trailer hitch and accidently pinched and partailly cut the wiring harness in the frame. I lost all lights except headlights. Anyway, I re-spliced the wires and everything works EXCEPT my turn signals. Here's the wierd thing, the emergency flashers work fine. I also cannot find a seperate fuse for the turn signals either. I don't believe it has the standard Ford flasher. It has an expensive Bosch flasher on a seperate little fuse block. I'm lost at this point. Where should I start? I'm assuming the wires are ok now or the flashers wouldn't work, would they?
HELP
Old 03-20-2006, 03:20 PM
Re: Turn Signal Trouble
Never Mind....Found it!
