Old 03-17-2006, 11:53 PM
canonoch canonoch is offline
Unhappy 94 starts and dies
Hi all,
Got a 94 Lesabre, Wife went to work, went to leave, started car, and car dies.
It seems like it will start no prob and run while cranking when key goes to run position it dies. Sets no codes
Tech has replaced crank sensor, ICM, Pass Module, ECM. Still no luck.
Any Ideas, Suggestion, or solutions
All answers Appreciated
Old 03-18-2006, 05:24 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 94 starts and dies
A faulty VATS module could cause the car to stall once the engine is running. The module sends a Pulse Width Modulated signal to the PCM. If this signal is not present, the PCM will not provide injector pulses thus causing the engine to stall. Have your injectors tested with a noid light while stalled, or not starting.
Old 03-18-2006, 11:43 AM
davey 58 davey 58 is offline
had same problem on 95 it was bcm tried used one still running $60.00
Old 03-31-2006, 04:20 PM
dmblover4136 dmblover4136 is offline
I had the same problem and it was the air filter hose had a small cut in it. This might work might not
