Old 03-17-2006, 08:12 PM
diannebudzinski diannebudzinski is offline
91 Park Ave Parking lights won't shut off
My parking lights won't shut off, and i can't find the fuse to turn them off. I have tried every fuse and every other light turned off just fine. the problem started about a week ago, i came out of work and my battery was dead. I got a new battery and terminals had the alternator checked and everything was fine. that night i couldn't get the headlights on. i played with the steering colum, moving it up and down and pulling on the high beam light and well it started working when i was half way down the hill.
Now tonite, my parking lights won't shut off. i think there is a short somewhere in the electrical system, because sometimes things just stop working. ie; the power seats.
Also the heater blower sometimes doesn't turn on unless i open the hood and slam it down then wala.....i have heat
Someone please help, i got fed up tonite and just disconnected the battery.
Old 03-18-2006, 05:43 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 91 Park Ave Parking lights won't shut off
You have a fuse panel under the drivers side dash as shown below. It looks like fuse #14 is for the parking lights. You may have a stuck relay or a bad switch. The blower fan motor may be going bad, if vibration will cause it to start running.
