Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-17-2006, 06:06 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Head is Knocking
I am having a wierd knocking/pinging sound coming from what I can tell is the pulley side of the head. I havn't pulled the valve cover yet, but I have good oil pressure I know. Does anyone have some ideas on what it could be? It sounds the worst at about 2000 RPM. I don't hear it at idle or past about 3000 RPM. Thanks for the help. Plus I need to drive it 220 miles home on sunday, so fast responses would be appreciated.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 03-17-2006, 07:19 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Head is Knocking
Is it RPM dependent. Unplug each spark plug wire one at a time and see if the sound changes. If it does, then it's most likely rod knock, if not, might just be lifter tick
now - 2000 civic
soon - 2002 is300
Old 03-17-2006, 07:33 PM
95_GSX's Avatar
its deffinatley RPM dependent, I was thinking possibly my Balance Shaft belt broke. But I dont know much about them. It is a really loud knock when it happens. I will look into more in the morning. Any other ideas?
Got AWD?
'08 Buell 1125R
Old 03-17-2006, 09:37 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
I do not believe its a balance shaft belt. Why i say this is because when mine broke i left it alone for 3 months and did not hurt anything. If it dependent with rpms it might be a rod. Does it sound like a low ping knock or a high ping? High ping is most likely head and low is the bottom end
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 03-17-2006, 11:31 PM
Originally Posted by crunchymilk55
Unplug each spark plug wire one at a time and see if the sound changes. If it does, then it's most likely rod knock in that cylinder, if not, might just be lifter tick
Did you do this yet? Simple, easy, and accurate. Just don't shock yourself.
now - 2000 civic
soon - 2002 is300
Old 03-18-2006, 06:47 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I've heard of warped exhaust manifolds making funny knocking noises too.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-18-2006, 12:44 PM
95_GSX's Avatar
I tried pulling spark plugs but I didn't hear any difference in tone. I didn't take the motor up in rpms either though. Maybe I will try that.
EDIT----->Well I tried it at about 2000 rpm and it sounded like the knock went away. So it sounds like I need a new motor. Does anyone know any other test to check for rod knock?
Got AWD?
'08 Buell 1125R
Old 03-18-2006, 02:49 PM
I meant to take the spark plug wire out, but I guess it would have the same effect. If you didn't hear any difference in sound, then you don't have rod knock
now - 2000 civic
soon - 2002 is300
Old 03-18-2006, 05:53 PM
95_GSX's Avatar
I knew what you meant, and that is all I did. I was just typing to fast and I didn't edit my post before I submitted it. Its deffinately a Rod. So now begins the hunt for another engine.
Got AWD?
'08 Buell 1125R
Old 03-18-2006, 06:07 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I thought you said it didn't change when you pulled the wires, if it doesn't change on any cylinder than it's not rod knock.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-18-2006, 10:58 PM
95_GSX's Avatar
If you had read the edit in that post where I tried it at about 2000 RPM you would have seen were I said there was a change in tone.
Got AWD?
'08 Buell 1125R
Old 03-18-2006, 11:09 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
sounds like 6 bolt time
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 03-19-2006, 09:12 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Stroker time!
1991 GSX 2.3 Stroker
Old 03-19-2006, 09:52 AM
95_GSX's Avatar
I wish I could build a motor right now, but I cant afford it with college. I am just going get a JDM motor (hopefully with low miles) from a japan importer for as cheap as I can and swap it in. Then I will build a motor in another couple of years.
Got AWD?
'08 Buell 1125R
