Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 03-17-2006, 07:01 PM
blackhawk911 blackhawk911 is offline
handbrake issue
I have kind of a weird problem with the handbrake on my 96 G20. Well if I use my handbrake to much the piece on the brakes that makes the car stop when using the handbrake tightens up the more I use the handbrake. Every time it dose this I have to take the wheel off and untighten them. But this problem only happens on the rear tires. So I hope that some one knows a fix for this because I dont want to spend the time and the money getting new calipers.
Old 03-19-2006, 10:21 AM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Re: handbrake issue
The reason it only happens on the rear tires is because the handbrake only affects the rear tires. Also, I am having a hard time understanding the problem... Are you trying to say that when you use the handbrake, the e-brake fails to release whenever you put the brake back down?
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 03-20-2006, 08:21 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Re: handbrake issue
sounds like an E-brake cable is siezed ..
Re: handbrake issue
Old 03-26-2006, 05:32 PM
speediva's Avatar
Re: handbrake issue
I saw you elaborated on your problem over on G20.net Glad you are working on a fix (I didn't finish reading the thread)
Inform yourself:
AF User Guidelines
