Old 03-17-2006, 05:05 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Stock 1g J-pipe Question
It has that little nipple, Not really sure why, but what did you all do to plug it?? Against my wishes I'm doing a 14b install in the 2g! Did anyone just cut it off and JB-weld it? I don't get what its for, seeing that it would cause one nice boost leak...
Old 03-17-2006, 08:40 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: Stock 1g J-pipe Question
Ummm what little nipple? I got a stock 1g J pipe and it had nothing what your explaining. Post a pic of it you know better j/k man
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 03-17-2006, 10:37 PM
SLoe's Avatar
SLoe SLoe is offline
Boost source to WG. (ithink) Mine had that also, but I'm not going to use the stock j pipe so IDK. If I had used it I would have cut it off flush and welded it. I don't trust JB that far. If you don't have access to a welder, you could put a vacuum cap and a small screw clamp on so it doesn't blow off.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 03-17-2006, 10:58 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Vacuum cap it. I had to put one of those on the compressor housing when doing the MBC install. It came in a pack of like 2-3 for cheap.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 03-17-2006, 11:29 PM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
I have a stock 1g j-pipe. It links to the wastegate. I have an MBC in the line but I'll check it out tomorrow and let you know how I have it all routed. No boost leaks as far as I know and my MBC sticks where I set it like a champ.
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 03-17-2006, 11:34 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
they have little caps at vatozone or whatever. Plug it with the smallest one you can, then get a zip tie on it as tight as possible. Problem solved. It was there for a pressure source originally, I believe to the wastegate iirc.
now - 2000 civic
soon - 2002 is300
Old 03-17-2006, 11:41 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Yeah it' for the wg, it goe to the stock boost control solenoid. If you don't have a welder and want it to look pretty clean (no offense to the other suggestions) you could get a small bolt and tap it and bolt it on, that way you're sure it wont leak, iirc that line isn't flared so a cap would likely slip off.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-18-2006, 12:04 AM
SLoe's Avatar
Old 03-18-2006, 09:09 AM
That answered my question.. Im going to cut it off and jb-weld it after I pollish it.
