Old 03-17-2006, 03:54 PM
pbfreak98 pbfreak98 is offline
I don't know what this light is.
A light came on in my car yesterday, it's red and it's like a box with a spout on top. Inside is an arrow pointing down toward some fluid. I put antifreeze and powersteering fluid in but the light is still on. Can someone tell me what this light means?
Old 03-17-2006, 06:41 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: I don't know what this light is.
gas?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 03-17-2006, 06:42 PM
No, I think the low coolant sensor is screwed up.
Old 03-17-2006, 07:26 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
if its what im thinking of its your low coolant light, ill look at mine and see exactly what it looks like to make sure, if thats what it is, mine comes on AT LEAST once a day, everytime im on a hill or make a turn fast, it comes on and stays on for hours at a time
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 03-17-2006, 07:27 PM
Ok thanks
Old 03-17-2006, 08:03 PM
quake61's Avatar
quake61 quake61 is offline
yes is the coolant light and u better get that checked
check the coolant level and spot for any leak
Old 03-19-2006, 02:11 AM
yep i looked at my car, that sounds exactly like the low coolant light, just check your fluid, make sure its full, and if it is i would just ignore that light, just keep an eye on the temperature guage, like i said, that light comes on constantly in my car and ive never had any problems
Old 04-03-2006, 10:24 AM
ericws73 ericws73 is offline
Same problem here. My switch sticks sometimes. The switch is in the bottom front of the plastic coolant reservoir. I cleaned the tank out once and the switch started working, but it only lasted a couple of weeks before it stuck again. I just keep an eye on the temp gage now and ignore the light.
Old 04-03-2006, 03:17 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
My coolant light hasn't bothered me yet, it must just be a faulty sensor or something. Just keep ur eye on the coolant level once and awhile and it should be fine.
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 04-03-2006, 05:48 PM
Thanks everyone for the help but it went away by itself the other day.
Old 04-03-2006, 05:54 PM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
still check your fluid though
Old 04-03-2006, 08:08 PM
quake61's Avatar
that means your coolant is low. check ur antifreeze lever and also check for leaks
