Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 03-17-2006, 02:29 PM
powwow944 powwow944 is offline
Pressure Problems
last week i had to replace the gasket set on my oil cooler and a couple other leaks that were on my 944. just wanted all the leaks to stop. Well now i got an even bigger leak. I've tried 2 seprate types of oil filters and everytime it seems to blow out my oil filter gasket. if anyone could give me any advise i'd appreciate it.
Old 03-21-2006, 05:55 AM
ledhedsymbols's Avatar
ledhedsymbols ledhedsymbols is offline
Send a message via AIM to ledhedsymbols
Re: Pressure Problems
First:
What type of filter are you using? I recommend the Mahle. The dealer or a good independent Porsche shop should carry it. If not, you can buy them by the lot on sleaze-bay.
Second:
Are you lubricating the gasket with a little bit of motor oil before you install it, and are you tightening ONLY hand tight?
"I'm a simple man really, all I need is enough sleep for two men, enough drink for three, and enough women for four." -Walter Slovotsky
Black 1993 Porsche 968 Coupe (official compensation vehicle.) 1999 Ford Ranger (Fishing and Track Support Vehicle) 1999 Toyota Corolla (Official low maintenance, high gas mileage commuter car)
Old 03-23-2006, 02:04 PM
zero_porsche zero_porsche is offline
i just replaced my oil cooler gasket over spring break too. when the oil cooler gasket is off the car there is the plug that is a allen wrench, and a spring that is below the plug. did you mess with that because that has to do with the oil pressure.
