Help,
I noticed recently that I was loosing coolent and couldn't find any leaks. I kept adding about half gallon every couple of days until it got worse no I noticed it is all in htoil also. Are these things known for head gasket problems? I took the heads off and can't seem to find where it may have been leaking into the cylinders. Any input would be helpful, Thanks... |
Re: coolent in oil
Need more info. Year, engine, mileage to start with. As I'm sure you are aware it's going to need to be delt with before you run it any more than you already have.
...any tool dropped will roll to the exact geographic center of the vehicle. |
Re: coolent in oil
Re: coolant in oil
99 Suburban, 112,000 miles 5.7 vortec V8.
I remved the intake and the heads. Can't seem to see where the gaskets failed. I guess I should send these heads out for inspection. Just wanted to know what the common failures are with these engines. Seems like a few threads on this site about leaking intake gaskets. Engine didn't freeze up there was plenty of anti freeze in it and I kept adding more not just water. It started loosing a couple of months ago and progressively got worse. I kept an eye on the oil for the past couple of weeks then noticed the oil was contaminated with the coolant so I shut her down and ripped the top off the engine. |
Re: coolant in oil
