Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-17-2006, 01:37 PM
golk75 golk75 is offline
1994 Boneville BCM
Does anyone knows where the Body Control Module is located in a 1994 Pontiac Boneville, i guess mine its bad and it keeps cutting off the fuel.
Thanks
Old 03-17-2006, 03:18 PM
maxwedge maxwedge is offline
A990 racer
Re: 1994 Boneville BCM
No bcm in that car, what exactly is happening what has been done to determine the fuel is cutting off?
Old 03-17-2006, 04:18 PM
Car its really hard to start , it acts like if it was out of gas, then when you drive it all of a sudden it wont go no more and as soon as you stop it dies.
I took it to service shop to read the code and they says that the code was a BCM failure as well as a bad mass air sensor.
Old 03-19-2006, 10:46 PM
jdq jdq is offline
Check your fuel pressure, and vacuum air pressure.With mass airflow sensor when it starts you will most likely get surging in RPMS and when you stop sometimes it will stall,but so could a leak in your vacuum lines.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
