Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-17-2006, 01:12 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Need help replacing front struts on 01 sunfire
Any detailed instructions on replacing the front struts on an 01 sunfire? Trying to save someone $540 going to shop.
Old 03-19-2006, 08:09 AM
batman13's Avatar
batman13 batman13 is offline
Re: Need help replacing front struts on 01 sunfire
jack car up,
brace axle,
remove old struts,
install new struts,
there really is no detailed way to do it, just make sure you brace anything that is connected to the bottom end of the strut. or else it will fall down go boom . not fun when you're under there . don't do it alone. have a portable phone nearby and when you start working dial 9-1... just kidding.
block the rear tires so she don't roll over.
there's a lot of work involved, because of the limited space.
I might be able to lend a hand if you're nearby.
Good Luck
'97 Dakota "Fearless"
'00 Sunfire "Ninja"
Old 03-25-2006, 09:33 PM
Lances133's Avatar
So i wouldnt have to compress the springs or anything with that? I'm looking for info for a friend to save her like $500 going to a shop, and i've never replaced struts but i know people who can help if it's easy enough.
Old 03-26-2006, 07:28 AM
batman13's Avatar
when the car is jacked up,as long as you use the frame, the springs aren't under pressure.
if you can get struts and springs already together, you're set
but if not, you'll need to assemble them before you put them on the car but because for the setup, the springs shouldn't need to be compressed, you might need to fight to get them into position
I need to do mine soon (6-$700)
'00 Sunfire "Ninja"
