Old 03-17-2006, 01:06 PM
ronhow ronhow is offline
Starting Problems
I have a 93 Cavalier Z24 3.1 engine that is driving me crazy. Some times this thing will start right up and the next time it will crank but wont start. I have took notice that sometimes the dash lights don't come on when the key is in the on position. And that is when it generally won't start. Sometimes I can be driving down the road and it will just stop like the key was shut off. It will start back up after tuning the on and off repeatedly. I also notice that when the car won't start , not only will the dash lights not come on, you do not hear the fuel pump kick on. Everything else works in the on position, like radio,heater, headlights, blinkers etc. Now this may sound crazy but the other day I was fooling around with it and got it started and turned on the blinker and it just died. Maybe it just decided to quit running at that time, Ii don't know for sure. At this time it will not start at all. Cannot get the dash lights to come on at all. But it will still tund over but won't start. Any suggestions?
Old 03-23-2006, 01:11 PM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
Re: Starting Problems
try checking the wire to the starter it could be shorting out it is a fusible link so if its bad dont replace with regular wire. use fusible link wire
1993 HONDA CIVIC EX
BLITZ FRNT M3 SIDE BLACK WIDOW REAR
JSP TERMINATOR WING
17' MOTEGI SUPER SILVER RIMS
D16Z SOHC 1.6 VTEC
SKUNK2 INTAKE MANIFOLD
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
T25 CUSTOM TURBO KIT @ 7PSI
TUBULAR MANIFOLD
AIR TO AIR INTERCOOLER
ALCOHOL INJECTION
18002 TURBO MILES AT 218002 MILES GOING 140MPH FINALLY WENT
BUT, STILL GOT ME HOME
