Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-17-2006, 11:47 AM
hawkgs hawkgs is offline
Send a message via MSN to hawkgs
Have to replace the tranny....
Hi all, i just replace the tranny of my maxima 2000 and fix a problem with the old one, but these tranny some times kick hardthe 2nd gear and sometimes too desactivate the overdrive but the overdrive on/off light doesn't come on (overdrive still activate), if i stop and run again the overdrive work fine again...
Most of the time the tranny works really fine but these troubles happend every day.....
PD. The old tranny was from a older year maxima but doesn't have the overdrive problem....
any help'll be appreciated... thanks.
Old 03-17-2006, 02:02 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Have to replace the tranny....
A/T self diag w/o tools, see FSM page AT-48. (See Favorite links on my home page)
...items picked from FSM:
- This malfunction is detected when the A/T does not shift into
fourth gear position or the torque converter clutch does not
lock up as instructed by the TCM. This is not caused by electrical
malfunction (circuits open or shorted) but by mechanical
malfunction such as control valve sticking, improper solenoid
valve operation, malfunctioning oil pump or torque converter
clutch, etc.
- Possible Cause:
I Shift solenoid valve A
I Shift solenoid valve B
I Line pressure solenoid valve
I Each clutch
I Hydraulic control circuit
- Make sure that output voltage of A/T fluid temperature sensor
is within the range below.
FLUID TEMP SEN: 0.4 - 1.5V
If out of range, drive the vehicle to decrease the voltage (warm
up the fluid) or stop engine to increase the voltage (cool down
the fluid).
(...low voltage and/or contact problems may show up in here; check)
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
