Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 07-05-2002, 08:30 PM
guyt guyt is offline
Rebuilt 403 Help!!
I REBUILT A 78 403 HEADS REDONE BLOCK .030 CRANK .020-.020
8.5 TO 1 PISTONS 83CC HEADS EDELBROCK PEFORMER CAM AND INTAKE. MY PROBLEM IS THE MOTOR IS A DOG AND WILL NOT RUN RIGHT. I TOOK IT APART TO MAKE SURE THE CHAIN WAS ON RIGHT AND IT WAS. THEN I FOUND OUT I ONLY HAVE ABOUT 100 TO 115 PSI OF CYL. PRESSURE AND I DONT KNOW WHY. I SHIMMED UP THE ROCKERS AND I GOT 125PSI. BUT THIS IS STILL TO LOW. ANY HELP?
THANK YOU
Old 10-18-2002, 10:16 PM
Nick LaBorde Nick LaBorde is offline
olds 403 driveability problem
Have you solved your low power problem with your olds? If so what did you find, if not maybe i can offer some ideas.
Old 10-20-2002, 04:53 PM
OLDS 403
I assume that when assembled the engine you chose a cam that was a little more agressive than stock. If the information I've been given is correct, the answer is as follows. 1. if your cam has .500" lift, a fully adjustable valvetrain is required. If it falls in somewhere below the .500" lift mark than you can get away with using adjustable rocker pivots or adjustable pushrods, which are available from Mondello performance products (Oldsmobiles are these guy's specialty).There web site is www.mondellotwister.com
If you didn't install a radical cam and are having this problem, it may not be valve train related. In your posting you mentioned a lack of compression, after getting readings did you give the low cylinders a few drops of engine oil and re-test? if adding oil to low cylinders icreases the results, this indicates a ring sealing issue. If results do not change then it is probably valvetrain or head gasket related. Another question I have is, when the cam was installed did you follow the insructions for proper degreeing? If the cam timing is wrong the engine will also be pretty gutless.
4l60e Transmission out again...need help remington8189 Silverado 6 10-08-2014 04:16 PM
2000 Toyota Camry Rebuilt Transmission Computer Problem gujuchokra Camry/Camry Hybrid/Vista 5 08-20-2009 08:45 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
car burnt up aless than 150 miles trans rebuilt PLEASE HELP fmw2525 Regal 2 03-21-2008 09:10 PM
No oil pressure on rebuilt d16z6,HELP!! Bori '88 - '91 Civic | CRX | Wagon | Shuttlee 1 06-23-2004 02:07 PM
